Update System
  3800SC headers
3800SC headers by 88Formula3800
Started on: 11-04-2012 12:46 PM
Replies: 10 (2108 views)
Last post by: DimeMachine on 08-10-2013 08:56 AM
88Formula3800
Report this Post11-04-2012 12:46 PM Click Here to See the Profile for 88Formula3800Send a Private Message to 88Formula3800Edit/Delete MessageReply w/QuoteDirect Link to This Post
I am building a L67 to put in my 88 Formula right now, and on a budget so I figure my best bet is some SSAC headers for $225 shipped since with a new flex joint, clamps, and lots of RTV these seam to get great reviews in the Grand Prix community. Now I was wondering if anybody has used these headers in ther 3800SC Fiero? I am sure they will have to be modified to fit especially if I want to keep my trunk... Any dot have some pictures or anything I may find useful? Thanks for any input!
ALJR
Report this Post11-04-2012 09:07 PM Click Here to See the Profile for ALJRSend a Private Message to ALJREdit/Delete MessageReply w/QuoteDirect Link to This Post
Welcome to the forum!
Use the search; this has been covered numerious time. Sorry, I never saved any of the links so I cant post them, but the search should provide you with more info than you want...
Jefrysuko
Total ratings: 108
Report this Post11-05-2012 12:43 PM Click Here to See the Profile for JefrysukoSend a Private Message to JefrysukoEdit/Delete MessageReply w/QuoteDirect Link to This Post
You mean these headers?
Note that I cut the crossover pipe in three pieces and moved the joint for the front bank back further to gain clearance to throw out bearing release lever. If you are running an automatic you wouldn't need to do that but the crossover did not fit at all the way it was shipped and you probably want a bellows in there anyways. Mine came out really well in the end.
Also notice that I cut the bellows off the outlet as well. It hangs down below the cradle otherwise.
I was not able to avoid cutting the trunk but I figured that if I was going to go through the effort of headers that I wasn't going to sacrifice downstream in the exhaust system. I kind of doubt that even with removing the bellows there would be clearance to the trunk.
revin
Total ratings: 234
Report this Post11-05-2012 01:41 PM Click Here to See the Profile for revinSend a Private Message to revinEdit/Delete MessageReply w/QuoteDirect Link to This Post
On a budget? just use the stock manifolds. Just as good, no trunk cut either.
[This message has been edited by revin (edited 11-06-2012).]
James Bond 007
Total ratings: 263
Report this Post11-05-2012 08:34 PM Click Here to See the Profile for James Bond 007Send a Private Message to James Bond 007Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by revin:
On a budget? just use the stock manifolds. Just as good, no trunck cut either.
I agee! Allso the, Fiero exhaust is short, that means more HP.
88Formula3800
Report this Post11-10-2012 05:24 PM Click Here to See the Profile for 88Formula3800Send a Private Message to 88Formula3800Edit/Delete MessageReply w/QuoteDirect Link to This Post
I am going with XP cam and E85 with supporting mods, so I really do think headers are a good idea.
Jefrysuko, thanks a ton for that picture. Is there anyway that you could post a picture of what amount of cutting you did to your trunk, Thanks.
Jefrysuko
Total ratings: 108
Report this Post11-10-2012 06:23 PM Click Here to See the Profile for JefrysukoSend a Private Message to JefrysukoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I cut out the entire lower section which gave me enough room for the V8 F-Body Magnaflow (3" in and dual 2.5" out) muffler and keep it up high enough that it couldn't be seen from the rear of the car. I don't have it in the car right now so I can't really take a picture of how it all fits.
Report this Post11-10-2012 07:50 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Almost correct. The rear 3800 manifold is non-restrictive and flows well but the front cast iron exhaust manifold is restrictive, The system can be upgraded with a ZZ Performance Powerlog manifold for $159.00 and that producs a very good flowing 3800 exhaust ystem. . There is good info on this on the ZZ Performance website.
http://shop.zzperformance.c...nless-Power-Log.aspx
Take a look at the rear manifold cross section cut and ther write-up.
88Formula3800
Report this Post11-10-2012 08:49 PM Click Here to See the Profile for 88Formula3800Send a Private Message to 88Formula3800Edit/Delete MessageReply w/QuoteDirect Link to This Post
I already have ordered headers, 225 shipped. I am a sheetmetal worker by trade, so modifying things of this nature are not an issue. I just like to have a decent heads up of what I need to do, so that I have less figuring out later on lol
Jefrysuko
Total ratings: 108
Report this Post02-11-2013 11:34 PM Click Here to See the Profile for JefrysukoSend a Private Message to JefrysukoEdit/Delete MessageReply w/QuoteDirect Link to This Post
So did you get them?
DimeMachine
Report this Post08-10-2013 08:56 AM Click Here to See the Profile for DimeMachineSend a Private Message to DimeMachineEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well - lets see what you did?
84 NB, 3800SC, E-85, VS Cam, 3.0 Pulley, 4T65E-HD, HP Tuners, AEM Wideband, Regal GS Gauges, S-10 Brake Booster. 1/4 mile -12.05 at 111.7mph
