  Looking for 3800 torque specs
Looking for 3800 torque specs by MulletproofMonk
Started on: 09-24-2012 10:06 AM
Replies: 7 (1678 views)
Last post by: Lou and Blue on 06-01-2014 03:41 PM
MulletproofMonk
Total ratings: 78
Report this Post09-24-2012 10:06 AM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, I found some torque specs on another site.
Are the water pump bolts torque to yield?
Oil Pan: 10.42 Ft-Lbs or 125 In-Lbs
Oil Filter Adapter: 11 Ft-Lbs or 132 In-Lbs Note: 3800 II - Oil Filter Adapter - 2 Steps: 11FtLbs; +50deg
Valve Cover: 7.42 Ft-Lbs or 89 In-Lbs
Water Pump (Long Bolts): 15 Ft-Lbs or 180 In-Lbs Note: 3800 II - LONG Bolts - 2 Steps: 15FtLbs; +40deg
Water Pump (Short Bolts): 11 Ft-Lbs or 132 In-Lbs Note: 3800 II - SHORT Bolts - 2 Steps: 11FtLbs; +80deg
Water pump pulley: 115 in/lbs
Water Adapter/Connector: 11 Ft-Lbs or 132 In-Lbs
-Brian
Removing the roof panel
My HUD install thread
[This message has been edited by MulletproofMonk (edited 09-24-2012).]
Darth Fiero
Total ratings: 361
Report this Post09-24-2012 03:17 PM Click Here to See the Profile for Darth FieroClick Here to visit Darth Fiero's HomePageSend a Private Message to Darth FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
NO. But make sure you use thread sealer (like teflon paste) on the threads of the long bolts.
-ryan
OVERKILL IS UNDERRATED
[This message has been edited by Darth Fiero (edited 09-24-2012).]
Lou and Blue
Report this Post05-22-2014 10:10 AM Click Here to See the Profile for Lou and BlueSend a Private Message to Lou and BlueEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is there a site that shows the torque pattern too! I need torque specs for the oil pan, (I don't understand the +50 stuff) the supercharger, the lower intake manifold. Thanks
Louis
Louis Duet
Baldwin, Long Island, NY
Where driving hard is SOP.
"Blue" <= '85 Fiero GT
Stock V6---Stock everything. Trying to keep it 'mostly' that way. But I just got the 3800sc to swap into it!
"Boo" <= '81 Delorean DMC-12
The "DuetLorean"
VIN #5835
Stock PRV engine
Robertson Equipped
Neiland/Delman Engineered
Carbed and loving it! (Peugot 604 manifold) ---"Sorry purists"
Purple86GT
Total ratings: 62
Report this Post05-22-2014 10:27 AM Click Here to See the Profile for Purple86GTSend a Private Message to Purple86GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Louis
Check this site out: 3800SC torque specs
PaulJK
Total ratings: 237
Report this Post05-30-2014 06:44 AM Click Here to See the Profile for PaulJKSend a Private Message to PaulJKEdit/Delete MessageReply w/QuoteDirect Link to This Post
Link / site doesn't work
msrservices
Report this Post05-30-2014 04:55 PM Click Here to See the Profile for msrservicesClick Here to visit msrservices's HomePageSend a Private Message to msrservicesEdit/Delete MessageReply w/QuoteDirect Link to This Post
Link worked for me.
Let me know if you have a problem, I can email you the page as a PDF
Lou and Blue
Report this Post06-01-2014 03:36 PM Click Here to See the Profile for Lou and BlueSend a Private Message to Lou and BlueEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can you please email me that page as a PDF? I can barely read it and it ones not show torque patterns just tightness right?
Thank you
Louis
Louis Duet
The "DuetLorean"
VIN #5835
Stock PRV engine
Robertson Equipped
[This message has been edited by Lou and Blue (edited 06-01-2014).]
Lou and Blue
Report this Post06-01-2014 03:41 PM Click Here to See the Profile for Lou and BlueSend a Private Message to Lou and BlueEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lou and Blue
Member since Dec 2013
Oh, and can someone please link me to the tool used after the torque wrench that does that +50 DEG tightening? I don't even know what the name of the tool is.
If I'm putting a 1999 exhaust manifold on a 1996 3800sc which torque setting do I use (1996 or 1999) ?
Can anyone post torque patterns for oil pan, LIM, and supercharger, and oil filter adapter please?
And which bolts use antiseize and which use thread locker?
Thanks so much guys! And Celthora.
Louis Duet
The "DuetLorean"
VIN #5835
Stock PRV engine
Robertson Equipped
