  3800 completed but is idling at almost 1700 rpm. help me slow her down!!!
3800 completed but is idling at almost 1700 rpm. help me slow her down!!! by lilrifleman1200
Started on: 07-06-2012 11:59 AM
Replies: 13 (312 views)
Last post by: druddle on 10-06-2013 01:32 PM
lilrifleman1200
Report this Post07-06-2012 11:59 AM Click Here to See the Profile for lilrifleman1200Click Here to visit lilrifleman1200's HomePageSend a Private Message to lilrifleman1200Edit/Delete MessageReply w/QuoteDirect Link to This Post
3800 completed but is idling at almost 1700 rpm. i have checked all the vacuum lines and fluids i have no air leaks and the throttle body is working just fine. cant this me a computer problem???
Total ratings: 290
Report this Post07-06-2012 01:43 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sure it could. You should start by removing the IAC and then inserting your finger to fully seal off the passage that has vacuum on it. Does the engine stall, or run well below idle speed? If so then you know the problem is the IAC pintle too retracted. The next question will be is the problem caused by the IAC, the PCM to IAC wiring, or directed by the PCM itself.
If sealing the IAC with your finger however does not slow down your idle speed, then you need to look for either a vacuum leak or a non-fully closed throttle
lilrifleman1200
Report this Post07-10-2012 09:04 PM Click Here to See the Profile for lilrifleman1200Click Here to visit lilrifleman1200's HomePageSend a Private Message to lilrifleman1200Edit/Delete MessageReply w/QuoteDirect Link to This Post
i took off the IACand placed my thumb over it and still had a high idle i also replaced the IAC and its still running at 1700 rpm. then i put vac plugs on all the vacuum lines and ports and still no change... i am completely stumped at this point
Ryanstalin
Report this Post07-10-2012 09:07 PM Click Here to See the Profile for RyanstalinSend a Private Message to RyanstalinEdit/Delete MessageReply w/QuoteDirect Link to This Post
could a bad map cause this, and/or egr valve being stuck open?
lilrifleman1200
Report this Post07-10-2012 09:15 PM Click Here to See the Profile for lilrifleman1200Click Here to visit lilrifleman1200's HomePageSend a Private Message to lilrifleman1200Edit/Delete MessageReply w/QuoteDirect Link to This Post
i was thinking that also so i took them both off and did a delete on both... same issue... so i put them back on.
crashyoung
Report this Post07-10-2012 10:36 PM Click Here to See the Profile for crashyoungSend a Private Message to crashyoungEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did you plug the large hoses on the manifold? one is the PVC, the other is for the brake booster. Then there are the vapor recovery lines...
Mike Gonzalez
Total ratings: 130
Report this Post07-10-2012 11:12 PM Click Here to See the Profile for Mike GonzalezSend a Private Message to Mike GonzalezEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are you sure the throttle cable is allowing the TB to close all the way ?
Total ratings: 290
Report this Post07-10-2012 11:52 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
For the engine to run at 1700 rpm, somehow air is getting into the intake manifold. Vacuum lines disconnected are not going to get you to that speed, with perhaps the exception of the large vacuum brake booster line.
You covered the IAC hole and the engine still ran fast. That eliminates the IAC, the IAC wiring, the PCM and any electronic sensors.
Is your throttle closing completely?
Did you eliminate the EGR valve and not fully seal the hole in the lower intake manifold?
Pappy
Report this Post07-11-2012 01:29 AM Click Here to See the Profile for PappySend a Private Message to PappyEdit/Delete MessageReply w/QuoteDirect Link to This Post
x2 and check for interference issues front to back cable wise
[This message has been edited by Pappy (edited 07-11-2012).]
darkhorizon
Total ratings: 451
Report this Post07-11-2012 12:20 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I doubt your thumb could have fit way down in the hole. to block the IAC passage you have to jam something all the way down the hole and seal it off completely.
druddle
Report this Post10-06-2013 11:45 AM Click Here to See the Profile for druddleSend a Private Message to druddleEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a very similar problem , I have put a new IAC on no change
I also checked for manifold leaks and throttle body leaks. Also throttle cable
Still no change. Did you ever find your problem?
FIEROFLYER
Total ratings: 180
Report this Post10-06-2013 01:27 PM Click Here to See the Profile for FIEROFLYERSend a Private Message to FIEROFLYEREdit/Delete MessageReply w/QuoteDirect Link to This Post
I would say double check the IAC again and make sure you are plugging it off completely as well as make sure the throttle is not being kept open some by the cable set up. If not check for vac leaks around the throttle body to manifold gasket and you did plug the larger vac port for the brake booster as I had one a few years ago with a small hole in the metal brake booster tube going through the car that was very hard to track down. Dan
lilrifleman1200
Report this Post10-06-2013 01:29 PM Click Here to See the Profile for lilrifleman1200Click Here to visit lilrifleman1200's HomePageSend a Private Message to lilrifleman1200Edit/Delete MessageReply w/QuoteDirect Link to This Post
Mine only does it after I drive it. Like after it's all nice and warm it won't slow down.
druddle
Report this Post10-06-2013 01:32 PM Click Here to See the Profile for druddleSend a Private Message to druddleEdit/Delete MessageReply w/QuoteDirect Link to This Post
