Click here to visit the donation page | View all sponsors
  Notchback to GT conversion, Wire harness removal
Notchback to GT conversion, Wire harness removal by hdryder
Started on: 07-04-2012 09:36 AM
Replies: 3 (92 views)
Last post by: Fiero84Freak on 07-04-2012 01:31 PM
hdryder
07-04-2012 09:36 AM Click Here to See the Profile for hdryderClick Here to Email hdryderSend a Private Message to hdryderEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am stripping my '87 GT rusted out parts car for a GT conversion on a '85 notchback.
Is there a disconnect point for the rear lamp wire harness, so I can remove it all in one piece?
Thanks for the help.
Fiero84Freak
Total ratings: 60
07-04-2012 09:42 AM Click Here to See the Profile for Fiero84FreakSend a Private Message to Fiero84FreakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah it's that connector that is sitting in "front" of the battery. One connection is for the main harness, and the other is for the rear tail harness assembly.
Once you remove all the body work pieces you'll see it a bit better.
hdryder
07-04-2012 12:20 PM Click Here to See the Profile for hdryderClick Here to Email hdryderSend a Private Message to hdryderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the info. I saw that it went up in that area, but did not see where it could come apart.
Is there any difference between an '85 GT rear lamp wire harness and a '85 2M4 rear lamp wire harness?
I have read about making a wiring change for the '86-'88 wire harness in a '85 GT, but not sure if the same or different wiring change would be used on a 2M4 car.
Fiero84Freak
Total ratings: 60
07-04-2012 01:31 PM Click Here to See the Profile for Fiero84FreakSend a Private Message to Fiero84FreakEdit/Delete MessageReply w/QuoteDirect Link to This Post
For an '85 GT to/from a notchback 2M4, no, because it is also a notchback. All notchbacks use the same wiring harness for the tail lamps. All fastbacks use the same harness for their tail lamps. You can switch between the same tail light assembly (like a notchback) from car to car without changing the harness, but if you change a notchback to fastback or a fastback to notchback you have to use the harness that came out of that specific car. There are also potential issues for having to do a little bit of wiring to make the stop lights work depending on what year you have. There are also some minor differences if you have say a six cylinder car from 1985 to 1987 as it will have a blower motor in the harness, but most of the items are rather miniscule that can be worked out.
From your original post though it sounds like you are swapping a notchback body piece for fastback body work, so if you do that yes you will have to do a little bit of extra work.
[This message has been edited by Fiero84Freak (edited 07-04-2012).]
