  88 brake pads
88 brake pads by Swampthing
Started on: 07-03-2012 08:41 AM
Replies: 24 (956 views)
Last post by: Jay-ID on 08-02-2013 10:47 PM
Swampthing
Report this Post07-03-2012 08:41 AM Click Here to See the Profile for SwampthingSend a Private Message to SwampthingEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have been researching brakes for my 88 base. I am getting a little confused though, all the auto parts stores list the front and rear pads as different. Mostly they have decent brands for the rears and econo-crap brand for the fronts. Then while reading on the fiero store it says that the front and rear are interchangeable what is the truth? Are the pads the same or not?
Report this Post07-03-2012 08:56 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
88 pads and rotors are the same. Beware the auto parts stores....
Marvin McInnis
Total ratings: 227
Report this Post07-03-2012 08:58 AM Click Here to See the Profile for Marvin McInnisClick Here to visit Marvin McInnis's HomePageSend a Private Message to Marvin McInnisEdit/Delete MessageReply w/QuoteDirect Link to This Post
'88 Fiero pads and rotors are the same, front and rear. "All the auto parts stores" around here list them correctly. The premium Wagner Thermoquiet part number is MX378, and a lot of other manufacturers seem to include "378" somewhere in the part number. '84 through '87 are different.
[This message has been edited by Marvin McInnis (edited 07-03-2012).]
Swampthing
Report this Post07-03-2012 08:59 AM Click Here to See the Profile for SwampthingSend a Private Message to SwampthingEdit/Delete MessageReply w/QuoteDirect Link to This Post
Weird, so all 88s use the same pads and rotors front to back? That seems really strange
Indiana_resto_guy
Total ratings: 163
Report this Post07-03-2012 09:33 AM Click Here to See the Profile for Indiana_resto_guySend a Private Message to Indiana_resto_guyEdit/Delete MessageReply w/QuoteDirect Link to This Post
yes same stuff
Report this Post07-03-2012 10:52 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
They use same piston size too but rear has less performance because GM uses a "True" proportion valve to bias the system. (Many have the myth that 88 have no bias...)
see my cave, combination valve and other articles in brake section.
BillS
Report this Post07-03-2012 12:01 PM Click Here to See the Profile for BillSSend a Private Message to BillSEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good pads for the 88 are hard to find.
I just popped in a set of EBC Greenstuff and they seem to be about the best that are reasonably available. Very good initial grip, BTW. I use their Redstuff on the Solstice - excellent!
Marvin McInnis
Total ratings: 227
Report this Post07-04-2012 12:55 AM Click Here to See the Profile for Marvin McInnisClick Here to visit Marvin McInnis's HomePageSend a Private Message to Marvin McInnisEdit/Delete MessageReply w/QuoteDirect Link to This Post
That has not been my experience. The Wagner Thermoquiet pads (MX378) I cited earlier are just one example. There are others.
Justinbart
Total ratings: 119
Report this Post07-04-2012 01:22 AM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
EBC !!!!!!!
Turbo 3800 E85 F23 5spd spec5
11.54@132.7
Swampthing
Report this Post07-04-2012 09:27 AM Click Here to See the Profile for SwampthingSend a Private Message to SwampthingEdit/Delete MessageReply w/QuoteDirect Link to This Post
When the time comes I will probably go with the Wagner's, I have no desire to deal with dusty organic brakes. What about rotors? New or get them turned?
mcguiver3
Report this Post07-04-2012 10:02 AM Click Here to See the Profile for mcguiver3Send a Private Message to mcguiver3Edit/Delete MessageReply w/QuoteDirect Link to This Post
In regard to brake pads, I found the Hawk HP Plus pads (HB100N) work great.
The thing is you have to drill out the retaining holes a bit and shave the backing plate sides about 1/16"
It gives us 88 guys another source for great pads.
I Autocross the car and this pad is by far the best around. Good initial bite when cool and terrific when hot.
Not much dust, excellent modulation, no fade, and rotor wear was good.
The car has been on a diet too, down to about 2200# but I have them on a street car (86 GT) and they perform well.
The rotors can be turned if within spec. New rotors are available. I bought a set from the Fiero Store and they were not too costly.
Advance Auto Parts carries them. I will look for the part number later.
Report this Post07-04-2012 11:42 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Depend on several things...
For 1... How bad the damage?
Front is thin to start with... any wear is easy to exceed the "machine to" spec.
See my cave, rotors spec in brake section.
Report this Post07-04-2012 02:49 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
I believe the front/rear pads for the 88's used to be different.
Shape/size they are the same, the only difference front/rear was that the rear had the little nubs that engaged the piston to keep it from spinning when the parking brake was used. Most of the sets I have purchased that were listed for front & rear were missing the little nubs. Never had any issue with them, but I do suspect that at one time they were different front/rear.
As for specific brands/compounds... entirely personal preference.
Swampthing
Report this Post07-04-2012 08:10 PM Click Here to See the Profile for SwampthingSend a Private Message to SwampthingEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just so i am completely clear the front and rears use the same pads despite the different appearing calipers?
Steve25
Report this Post07-04-2012 08:35 PM Click Here to See the Profile for Steve25Send a Private Message to Steve25Edit/Delete MessageReply w/QuoteDirect Link to This Post
I am very impressed with Greenstuff pads although they are quite dirty.
Does anyone have experience with Redstuff vs Greenstuff? Specifically initial bite, warm up required to get maximum braking (temperature range) and (waaaa) dust?
Steve AT 88GTP DOT com
88 GT\3800 SC\L67\L26\4T65E-HD
NIC Cam\Comp Cam Hi-Tech 1.8 rockers\Rhoads XL Lifters
eBay Headers\Magnaflow Camaro muffler, 3.4 pulley
DH Tune
Wanna go faster?
Report this Post07-04-2012 09:19 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 88 calipers (front and rear) look the same through the wheels and share the same bridge. The piston housing is different (one has parking brake, one is piston only) and the bleeder screws are in slightly different locations/angle. Since the 1988 pads sit within the bridge, and the bridge is the same front to rear, the overall shape of the pads ends up being the same as well.
Now if you are talking about the 84-87 fieros, those years do have different shaped pads front and rear.
[This message has been edited by fieroguru (edited 07-04-2012).]
Swampthing
Report this Post07-04-2012 09:56 PM Click Here to See the Profile for SwampthingSend a Private Message to SwampthingEdit/Delete MessageReply w/QuoteDirect Link to This Post
Mine look different, though i guess it could just be the brackets i guess tomorrow i will post pics and yall can explain it to me
Jay-ID
Report this Post07-25-2013 12:55 PM Click Here to See the Profile for Jay-IDSend a Private Message to Jay-IDEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just bought the EBC Greenstuff (DP2325) but they don't have the bumps / nubs on the inboard pad for the rear calipers. Reading through the archives here indicates that those alignment nubs keep the piston from spinning so that the parking brake works. Without the nubs then the parking brake wouldn't work correctly. Possibly the "self-adjusting" wouldn't work either.
Does anyone have experience with this? Did your parking brake work fine after installing pads without nubs? I'm trying to decide whether to install these pads today.
[This message has been edited by Jay-ID (edited 07-25-2013).]
jaskispyder
Total ratings: 205
Report this Post07-25-2013 01:06 PM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
FYI, I have swapped front calipers to the rear on an 88 (didn't need parking brake).... so just another tidbit to show they are interchangeable.
Jay-ID
Report this Post07-25-2013 01:28 PM Click Here to See the Profile for Jay-IDSend a Private Message to Jay-IDEdit/Delete MessageReply w/QuoteDirect Link to This Post
They do appear interchangeable. I'd just like to keep a working parking brake.
Jay-ID
Report this Post08-01-2013 12:58 PM Click Here to See the Profile for Jay-IDSend a Private Message to Jay-IDEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've gotten some confirmation from a shop and parts supplier that the nubs are needed in order for the parking brake to work. Anyone know if a good pad that has these nubs?
lateFormula
Report this Post08-01-2013 05:07 PM Click Here to See the Profile for lateFormulaSend a Private Message to lateFormulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Right now on my 88 I have EBC Greenstuffs on the rear , and Delco Durastops on the front. The EBC's do not have the nubs on them, and my parking brake works just fine. It will hold the car at a stop when in gear.
MadMark
Report this Post08-01-2013 06:37 PM Click Here to See the Profile for MadMarkSend a Private Message to MadMarkEdit/Delete MessageReply w/QuoteDirect Link to This Post
It is not the parking brake that is the problem if you don't have the nubs. It is the auto adjusting for the rear brakes that is affected by not having the nubs. When you actuate the rear parking brakes the nubs hold the piston from turning and then the parking brake actuator can self adjust the position of the brake caliper. The brakes will still work and so will the parking brake, but if the adjusters don't work right there is a little bit more of a lag when you push on the brake pedal as the rear caliper has more room to take up before touching the brake rotor.
I have used some pads that don't have the nubs on the rear and the brakes will still usually adjust, but it takes more effort to get them to do it. Like actuating the parking brake several times until the caliper piston catches properly.
lateFormula
Report this Post08-01-2013 10:03 PM Click Here to See the Profile for lateFormulaSend a Private Message to lateFormulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Exactly. After I installed the EBC pads I noticed on the first few drives that the pads made an audible scratching noise whenever I applied the brakes. As it turns out, the pistons did not adjust and they were not applying enough pressure on the rear rotors when I applied the brakes. I had to adjust them using the parking brake. The first few pulls on the parking brake gave no resistance, but after a few more pulls, the pistons got properly positioned. Now the rear brakes work quietly and the parking brake will hold the car.
Jay-ID
Report this Post08-02-2013 10:47 PM Click Here to See the Profile for Jay-IDSend a Private Message to Jay-IDEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you both. I can live with that behavior.
