  Door lock tumblers
Door lock tumblers by lordbg0205
Started on: 06-30-2012 08:42 AM
Replies: 5 (887 views)
Last post by: hdryder on 04-25-2014 12:19 PM
lordbg0205
Report this Post06-30-2012 08:42 AM Click Here to See the Profile for lordbg0205Send a Private Message to lordbg0205Edit/Delete MessageReply w/QuoteDirect Link to This Post
So im getting ready to install a new lock cylinder in the drivers door of my 87 GT, and I was wanting to know how do I get the cylinder rekeyed, or get the right one. The key has a "D" stamped in it near the top. Can the dealer do this? Where should I get the tumbler?
Dodgerunner
Total ratings: 323
Report this Post06-30-2012 11:20 AM Click Here to See the Profile for DodgerunnerClick Here to visit Dodgerunner's HomePageSend a Private Message to DodgerunnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can get replacement GM lock sets from any parts store and any key shop can rekey them to match your orig. if you want.
Old GM's are no big deal.
n7vrz
Report this Post06-30-2012 09:44 PM Click Here to See the Profile for n7vrzSend a Private Message to n7vrzEdit/Delete MessageReply w/QuoteDirect Link to This Post
When I bought my Fiero it didn't come with the door/trunk key. I just bought a tumbler set from The Fiero Store. Comes with keys.
88fieroduke
Report this Post06-30-2012 10:01 PM Click Here to See the Profile for 88fierodukeSend a Private Message to 88fierodukeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just took the tumblers out of my truck, so any similar GM key will work in my door locks, my fiero key, my grand prix key ect.
trotterlg
Report this Post06-30-2012 10:40 PM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can also just put in one or two of the sets. Just put your key you want to use in the lock and drop in the little pieces in one hole one at a time until you find a set in one hole that will allow that key to open it. Then that key will work but most other types probably will not. Larry
hdryder
Report this Post04-25-2014 12:19 PM Click Here to See the Profile for hdryderSend a Private Message to hdryderEdit/Delete MessageReply w/QuoteDirect Link to This Post
The linkage to the driver's door key tumbler has come off on my '88 GT. It is a bit hard to see inside even with the inner door panel off.
Is there a fastener that holds it on to the tumbler, or is it a type of 'keyed' fit connection?
Thanks for the help.
