Click here to visit The Fiero Store | View all sponsors
  Eibach Lowering springs
Eibach Lowering springs by pttransamdriver
Started on: 06-24-2012 01:45 AM
Replies: 6 (249 views)
Last post by: Blacktree on 06-25-2012 08:33 PM
pttransamdriver
06-24-2012 01:45 AM Click Here to See the Profile for pttransamdriverSend a Private Message to pttransamdriverEdit/Delete MessageReply w/QuoteDirect Link to This Post
So I installed my lowering springs and the back went down, no unsightly fender gap anymore, but the front....... nothing seems to have changed I haven't driven it yet because I don't yet have my custom axels for the engine swap I did. Does it settle or fix itself somehow? or do you have to chop the springs down some? Anybody know what to do here?
GraterFang
06-24-2012 01:52 AM Click Here to See the Profile for GraterFangSend a Private Message to GraterFangEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't have the eibachs personally but, yes, the car will settle when you first start driving it again. I wouldn't concern yourself about it until then.
Carcenomy
06-24-2012 07:28 AM Click Here to See the Profile for CarcenomyClick Here to visit Carcenomy's HomePageSend a Private Message to CarcenomyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah it'll settle down. These are my results with the Eibachs and Konis, no other suspension mods. Wheels are 235/35R19.
[This message has been edited by Carcenomy (edited 06-24-2012).]
zmcdonal
06-24-2012 07:29 PM Click Here to See the Profile for zmcdonalSend a Private Message to zmcdonalEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do you have rubber or poly bushings up front? If I recall from reading other threads if you have rubber the control arm bolts need to be tightened with the suspension loaded, for it to settle properly. I know when I had my Eibachs installed there was a definite difference in height before I drove it.
Carcenomy
06-25-2012 02:06 AM Click Here to See the Profile for CarcenomyClick Here to visit Carcenomy's HomePageSend a Private Message to CarcenomyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Mine's still rubber at the front... crikey, does that mean it might go lower when I install my poly?!
pttransamdriver
06-25-2012 04:56 PM Click Here to See the Profile for pttransamdriverSend a Private Message to pttransamdriverEdit/Delete MessageReply w/QuoteDirect Link to This Post
Oh thanks I feel better now the picture helps a lot too. Should I do polys up front? I heard that they squeak and aren't recommended, I want to put polys up front but I'd like to know all what you guys recommend.
Blacktree
Total ratings: 319
06-25-2012 08:33 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageClick Here to Email BlacktreeSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Carcenomy: Mine's still rubber at the front... crikey, does that mean it might go lower when I install my poly?!
If your rubber bushings are installed improperly, that could happen. But otherwise, no.
To the OP: if you have some ramps, you can drive the car up on them to give you room to get at the A-arm bolts. Loosen the bolts up a little bit (just enough so they'll turn in place), then bounce the front end up&down a bit. That should get rid of the pre-load in the rubber bushings.
That said, the front end on mine was also a bit high when I installed the Eibach springs. But that was because I couldn't get the rubber spring cushions fully seated on the suspension cross-member. After driving around a bit, they settled in.
