  Adding power windows and door locks to a Fiero
Adding power windows and door locks to a Fiero by Randy93552
Started on: 06-09-2012 12:54 PM
Replies: 20 (1543 views)
Last post by: Mike in Sydney on 07-04-2023 10:35 PM
Randy93552
Report this Post06-09-2012 12:54 PM Click Here to See the Profile for Randy93552Send a Private Message to Randy93552Edit/Delete MessageReply w/QuoteDirect Link to This Post
What is involved in doing this? What parts do I need to gather from the donor?
IFLYR22
Report this Post06-09-2012 01:00 PM Click Here to See the Profile for IFLYR22Send a Private Message to IFLYR22Edit/Delete MessageReply w/QuoteDirect Link to This Post
The doors from the donor.
It is a lot easier to add the doors with the power accessories to a car, than to add the power accessories to a door.
You will also need the wire harnesses, window switches and surround plate, and door lock relay.
Lock switches and interior door handle surround, if not swapping doors.
-Dave
Randy93552
Report this Post06-09-2012 01:41 PM Click Here to See the Profile for Randy93552Send a Private Message to Randy93552Edit/Delete MessageReply w/QuoteDirect Link to This Post
OK so I need to find a powered non-aero to swap doors with? I have an 88 Formula and an 87 GT. the GT has powered doors and the formula doesn't. When looking for a donor is aero my only concern? Are the doors the same on all years.
fierobear
Total ratings: 383
Report this Post06-09-2012 02:47 PM Click Here to See the Profile for fierobearSend a Private Message to fierobearEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, get the doors. It has been a while since I did this swap, but I seem to remember you will need the "cross car harness" that runs behind the dash. That carries the electrics for this.
Don't worry whether the doors are aero or not, unless you are determined not to change the door panels.
IFLYR22
Report this Post06-09-2012 06:25 PM Click Here to See the Profile for IFLYR22Send a Private Message to IFLYR22Edit/Delete MessageReply w/QuoteDirect Link to This Post
Any 85 through 88 door with power accessories will work. You can easily swap the outer and inner skins (panels) if needed. The 84's have a different way of mounting the outer door skins.
-Dave
[This message has been edited by IFLYR22 (edited 06-09-2012).]
josef644
Total ratings: 103
Report this Post06-09-2012 10:44 PM Click Here to See the Profile for josef644Send a Private Message to josef644Edit/Delete MessageReply w/QuoteDirect Link to This Post
The best way to do this is to remove the two front fenders. Then you can access the four bolts that hold the door frames to the chassis very easily. You can swap out the outside skins on the four doors, so no painting would be required.
This is the top hinge on the passenger side. Notice that the door part of the hinges is threaded from inside the door frame. Not fun to do that way.
[This message has been edited by josef644 (edited 06-09-2012).]
exoticse
Total ratings: 108
Report this Post03-30-2014 04:44 PM Click Here to See the Profile for exoticseSend a Private Message to exoticseEdit/Delete MessageReply w/QuoteDirect Link to This Post
ok sorry to revive an old thread, but i need to add the power door locks. my car has power windows, and i have acquired the power door lock setup but have no idea how to install it.
in addition i also have an alarm and remote door lock setup to install.
do i need to install the fiero power door locks and the remote door locks, both or just the latter ?
is there a tutorial on how to install power door lock setup ?
** edit - ok found this (below) !! **
http://www.michiganfieroclub.com/Tech_Tips.html
[This message has been edited by exoticse (edited 03-30-2014).]
jaskispyder
Total ratings: 205
Report this Post03-31-2014 07:47 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
I wrote up the tech article on the Michigan Fiero Club site.
I would not swap doors, as I have tried that and it is more pain than just swapping internals, as you have to align the door and the door panel. If you have a good door on the car, just swap the internals, and add the wiring harness for the interior.
SCCA FIERO
Total ratings: 93
Report this Post03-31-2014 08:21 AM Click Here to See the Profile for SCCA FIEROSend a Private Message to SCCA FIEROEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by jaskispyder:
I would not swap doors...
Me either. I added power windows, locks, and mirrors to my 88 Coupe, power locks and mirrors to my 87GT. I've also replaced a door.
88FieroGT TTops
Report this Post03-31-2014 09:13 PM Click Here to See the Profile for 88FieroGT TTopsSend a Private Message to 88FieroGT TTopsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I did mine in1989 before the internet and PFF. I had the Helm manual and I used that as my guide. If you are installing power to a non powered you will NEED the cross car harness--the junction block located above fuse box on driver sidewall in the dash area, the window regulators and motors, the lock solenoids, the power lock buttons (get new) the window switches and the plate they go on AND the silver circuit breakers that go in the fuse box. When I got my stuff it was all new from the dealer. I laid it out on the floor to see how it was going to go using the manual as the guide---since you will be using a donor, it would be good to look at the manual to get the wiring out of the donor. I would buy the doors and bring them home and disassemble them there--make note of how the stuff comes out of the donor--I know you all probably know this but I did mine with only a manual--use screws on reassembly-I did rivets and I think they loosened up and while you are doing it you might as well replace your dew wipes and the felt bumpers---hopes this helps some-----Have fun doing it! I did
Pat Jones
ksfastman
Report this Post04-06-2014 12:00 PM Click Here to See the Profile for ksfastmanSend a Private Message to ksfastmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've got an 87 GT with Pwr Wnd and Elec Mir, anybody know whether this harness has the Pwr Lck wiring also?
jaskispyder
Total ratings: 205
Report this Post04-06-2014 12:09 PM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
GM did not add extra wiring to fieros. Sorry.
So. If it wasn't an option you don't have wiring.
[This message has been edited by jaskispyder (edited 04-06-2014).]
ksfastman
Report this Post04-06-2014 12:12 PM Click Here to See the Profile for ksfastmanSend a Private Message to ksfastmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Figured it was probably wishful thinking on my part lol. Thanks
richard in nc
Report this Post07-02-2023 10:20 AM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
1987 car.im not finding any parts fieros around charlotte nc.are any parts from a firebird /camaro work.they seem to share a lot of parts.
Total ratings: 202
Report this Post07-02-2023 12:13 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hi Richard, check out the Fiero Factory... http://www.TheFieroFactory.com
Mike in Sydney
Report this Post07-02-2023 08:26 PM Click Here to See the Profile for Mike in SydneySend a Private Message to Mike in SydneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Try Hooper's Used Parts near Dallas, NC, 154 Hooper Hill Road (north of Gastonia). I got a fuel tank from a Fiero there a couple of months ago. (Was surprised they hadn't punctured it.) They may have what you are looking for. Also, PM me for the email of a person in Kinston that has a lot of Fiero parts. I've purchased brakes, engine cradle, GT steering wheels, consoles, front suspension cradle and a few other bits when I was in NC last year. Planning to pick up some other things he's holding for me in July when I get home.
[This message has been edited by Mike in Sydney (edited 07-02-2023).]
richard in nc
Report this Post07-02-2023 11:08 PM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
cool.
Total ratings: 202
Report this Post07-03-2023 09:20 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Wanted to add some more here... "back in the day," it made sense to swap doors from one Fiero to the next. That's because everything was still relatively new, and parts cars were plentiful. I myself would regularly see 2 or 3 Fieros in the junkyard every week that I'd go.
But it may not make sense anymore...
Most of the Fieros out there today ... where you would have access to a door from a donor car, is going to be really worn out. The seals will be dry-rotten, the dew strips are going to be trashed, and all the grease between the mechanisms are also going to be gummed up. Plus, if you want to keep your car original, your existing door is going to have the VIN and other sticks on the door that came with your car.
My opinion, if you have access to a donor vehicle. It makes much more sense to simply disassemble everything you need / want from the door (door lock brackets, actuator, linkage, and the wiring harness), and then install that in the new door WHILE also replacing the dew strips, vapor barrier, door locks, window guides, etc.
Just my 2 cents.
Mike in Sydney
Report this Post07-04-2023 05:37 AM Click Here to See the Profile for Mike in SydneySend a Private Message to Mike in SydneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is this supposed to be a PM? If so, click on the PM button on the right side.
richard in nc
Report this Post07-04-2023 05:56 PM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
im just trying to learn how this forum works.its much different than most.
Mike in Sydney
Report this Post07-04-2023 10:35 PM Click Here to See the Profile for Mike in SydneySend a Private Message to Mike in SydneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just click the PM button above the post. It's pretty intuitive.
