  Aluminum Cradle Bushings? Pro/Con
Aluminum Cradle Bushings? Pro/Con by Stainless1911
Started on: 05-26-2012 01:47 PM
Replies: 23 (2236 views)
Last post by: theogre on 07-23-2015 10:07 AM
Stainless1911
Report this Post05-26-2012 01:47 PM Click Here to See the Profile for Stainless1911Send a Private Message to Stainless1911Edit/Delete MessageReply w/QuoteDirect Link to This Post
http://www.rodneydickman.co...hingsFiero84-87.html
I ran across these today, and wondered what you guys thought about metal cradle bushings.
First thing that I thought of,m is that aluminum and steel don't mix, electrolysis corrosion through dissimilar metals.
I have a 1987 Fiero, 4 cylinder 5 speed.
raccoons
Report this Post05-26-2012 02:07 PM Click Here to See the Profile for raccoonsSend a Private Message to raccoonsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rubber bushings are not good for a performance car, and Pontiac fixed that by solid-mounting the '88 cradles. I have a set of Rodney's bushings, but haven't installed them yet (corrosion isn't as big of a deal in Texas though).
My project: 3800 Series III Supercharged + F40 6-speed into an 87 GT. Wish me luck!
Report this Post05-26-2012 02:43 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Electrolysis is not an issue. Plain old rust will get the steel long before the aluminum has any influence. Now, if you park your car in a foot of water there may be some electrolysis problems. You will find that the car will ride harder, but you probably don't care about that.
Stainless1911
Report this Post05-26-2012 02:59 PM Click Here to See the Profile for Stainless1911Send a Private Message to Stainless1911Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks. And no, Im not worried about if it rides a little harder.
I plan on just going through the car over the next few months, and making sure its mechanically sound. If I can upgrade to something like a hard mounted cradle while I already have things apart, and I can swing it, then that's what I'll do.
[This message has been edited by Stainless1911 (edited 05-26-2012).]
Blacktree
Total ratings: 350
Report this Post05-26-2012 04:00 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've had aluminum cradle bushings in my '87 Fiero since 2004. There have been no issues with electrolysis. But in order for electrolysis to happen, the parts would need to stay wet for long periods of time. So I don't think it's a concern.
That said, the aluminum cradle bushings will make the rear end feel more stable in a turn. The impact on ride quality is hardly noticeable, if at all.
Report this Post05-26-2012 05:41 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Aluminum cradle bushings are great but the question becomes, are they that much better than poly? Will you obtain any noticeable difference in performance between aluminum and poly? I have been using the Prothane poly cradle bushings and have been quite happy with the performance. The car stays straight under hard acceleration and the alignment stays in place.
I cannot see any negatives in using aluminum cradle bushings except that they are 2X the price and IMO probably don't give much if any additional performance.
Total ratings: 236
Report this Post05-26-2012 06:26 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
How do you know? Can you read a camber gauge on your outside rear wheel in the middle of a highly loaded corner?
Carver1
Total ratings: 62
Report this Post05-26-2012 07:02 PM Click Here to See the Profile for Carver1Send a Private Message to Carver1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yes! I strapped myself to his decklid last summer with a micrometer and he gave it hell. It was a little scary, but we got some good info......
11 Camaro SS/RS
86 Fiero GT 4.9
84 Fiero V6 Choptop?
03 Silverado 3500 Duramax! (Stacked, Tuned, Mean as Hell)
07 Suburban LT2
09 Avalanche LT3
i'm sure i could fly a plane no problem.
nosrac
Total ratings: 50
Report this Post05-26-2012 11:31 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
all PRO
thismanyfieros
Total ratings: 120
Report this Post05-26-2012 11:35 PM Click Here to See the Profile for thismanyfierosSend a Private Message to thismanyfierosEdit/Delete MessageReply w/QuoteDirect Link to This Post
lol Carver!!!
Stainless1911
Report this Post05-26-2012 11:36 PM Click Here to See the Profile for Stainless1911Send a Private Message to Stainless1911Edit/Delete MessageReply w/QuoteDirect Link to This Post
lol, video or it didnt happen.
Total ratings: 400
Report this Post05-27-2012 06:00 AM Click Here to See the Profile for Jake_DragonSend a Private Message to Jake_DragonEdit/Delete MessageReply w/QuoteDirect Link to This Post
My drive train is solid mounted, cradle, engine and trans mounts are all solid. The only rubber left is in the control arms.
I have had no issues with the car in the 8 or so years its been on the road.
Report this Post05-27-2012 08:13 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
You never measure alignment with the car running. It is always measured with the car sitting still and in my case the alignment stays put. Surely a talented highly skilled mechanic like yourself knows this,.
Total ratings: 236
Report this Post05-27-2012 09:44 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
And the "doesn't get it" award goes to...
Do I really have to belabor it *that* much?
[This message has been edited by Will (edited 05-27-2012).]
Total ratings: 236
Report this Post05-27-2012 09:46 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since Jun 2000
And flew from NM to NJ to do it, too! That's dedication...
ltlfrari
Total ratings: 127
Report this Post05-27-2012 12:56 PM Click Here to See the Profile for ltlfrariClick Here to visit ltlfrari's HomePageSend a Private Message to ltlfrariEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've got a set (not Rodney's ) on my 85 and it does make it handle better, not a lot but it is better. Just that bit less to flex/move. Of course, it'd be better if I replaced ALL the rubber suspension stuff with new or poly but other things to do first, like fix the ruddy a/c and paint and......(endless list!).
Dave
www.ltlfrari.com
Report this Post05-27-2012 03:37 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Depend on you live in road salt states and drive in winter....
Coatings, anodize etc, can affect the issue too.
Maybe you can seal al "bushings" and sleeve so water can't get inside the sleeve.
Using stock and some engine/trans swaps polly is very good.
Using polly cradle bushings and premium gas shock & struts stops or reduces many problem, including "Bump Steer."
Stainless1911
Report this Post05-27-2012 03:43 PM Click Here to See the Profile for Stainless1911Send a Private Message to Stainless1911Edit/Delete MessageReply w/QuoteDirect Link to This Post
I better go with poly, you might not believe this, but I got it for a winter car.
FieroWannaBe
Report this Post05-27-2012 05:12 PM Click Here to See the Profile for FieroWannaBeSend a Private Message to FieroWannaBeEdit/Delete MessageReply w/QuoteDirect Link to This Post
You better go Al then...
This is what happens to winter cars...
the rear of the car was not very well placed, and you could move the whole cradle with your foot when it was in the air. I would put as much support on the suspension as you can get. It makes a difference how your tires move in slippery conditions. That car was a beast to drive n snow, but I managed.
Stainless1911
Report this Post05-27-2012 05:31 PM Click Here to See the Profile for Stainless1911Send a Private Message to Stainless1911Edit/Delete MessageReply w/QuoteDirect Link to This Post
ugh, cant view the pic
TONY_C
Report this Post05-27-2012 06:06 PM Click Here to See the Profile for TONY_CSend a Private Message to TONY_CEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rodney's bushing are anodized, they won't corrode. Put some grease on the bolt when you assemble them. I think poly is a waste, you want the cradle rigid.
mcain1
Report this Post07-21-2015 07:24 PM Click Here to See the Profile for mcain1Send a Private Message to mcain1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Has anyone used the aluminum bushing with a 3800 swap? If so, do you feel anymore vibration when driving as compared to before?
Riddick85
Report this Post07-22-2015 10:31 PM Click Here to See the Profile for Riddick85Send a Private Message to Riddick85Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have a 3800sc swap with al cradle bushings and poly motor mounts and a solid dog bone. I feel no different vibrations driving compared to my 3.4 but at idle (about 750rpm) the whole car vibrates. At about 900 it doesn't do it anymore. I've just gotten used to it since I know it was all the changes I did that caused it.
I'd say go for aluminum since they will also probably never wear out even if they are more expensive
Report this Post07-23-2015 10:07 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
That can depend on trans used.
Auto trans load entire drive train all the time, including at idle. Harder/solid mounts and/or dog bone can and will vibrate more at idle. Most Dukes will vibrate allot then some others. (88 Duke w/ crank balance assm vibrate less I'm told.)
Drive around is not a big problem for most cars for added noise/vibration.
