  3800 S/C Fuel Rail
3800 S/C Fuel Rail by 355Fiero
Started on: 05-16-2012 04:32 PM
Replies: 9 (1346 views)
Last post by: TbirdMarc on 03-13-2014 03:32 PM
355Fiero
Report this Post05-16-2012 04:32 PM Click Here to See the Profile for 355FieroSend a Private Message to 355FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
For all you 3800 s/c experts out there. I am going to be swapping in a '97 3800 S/C into my 308 replica build and I need to buy a fuel rail and injectors for the motor. Didn't come with them. I found an '05 S/C L32 fuel rail on ebay motors but in looking around on the net, I can't determine if the '05 fuel rail will fit the '97 L67. Pretty sure the '05 had moved to the Series III from Series II so not sure if it will transfer over.
Also, I have put an ad asking for one in the Mall.
Thanks
Don
MstangsBware
Total ratings: 459
Report this Post05-16-2012 04:41 PM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks
Don
It will fit but not a direct fit and also you have to come up with a retunless system to run the newer rails. I will reply to you Ad in the Mall as I have what you need.....
Darth Fiero
Total ratings: 361
Report this Post05-16-2012 04:49 PM Click Here to See the Profile for Darth FieroClick Here to visit Darth Fiero's HomePageSend a Private Message to Darth FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Don, the L32 fuel rail will bolt right onto your engine. With a little modification (to the rail) it can be turned around on the engine so it faces the correct corner of the engine compartment to simplify fuel line routing.
Now, what you need to be aware of is the L32 fuel rail only has a supply line, is returnless, which means it doesn't have a fuel pressure regulator - which you are going to need.
I like using these L32 fuel rails in the swaps I do because they clean up the engine and simplify the fuel system that is on the top of the engine. But in order to use them, I custom build a remote fuel pressure regulator (from L67 fuel rail parts) and mount it down by the fuel filter.
-ryan
OVERKILL IS UNDERRATED
355Fiero
Report this Post05-16-2012 05:01 PM Click Here to See the Profile for 355FieroSend a Private Message to 355FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wow;
Fast replies. Thanks guys.
I have a couple PM's already as well for what I need and have replied. I am not too worried about the top of the engine really as the lines can be made to look pretty with paint etc. It is going into a Ferrari 308 replica so I might build a fake intake box that says Ferrari on it more like oem 308's.
If I do go the late model route, I will search the technical discussion area and find the thread on how to do it. I am sure it would be in there somewhere.....
Again, thanks for the replies.
Cheers
Don
Darth Fiero
Total ratings: 361
Report this Post05-16-2012 05:19 PM Click Here to See the Profile for Darth FieroClick Here to visit Darth Fiero's HomePageSend a Private Message to Darth FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just made this webpage showing some pictures explaining some of the mods that need to be done to the rail...
http://www.gmtuners.com/fiero/returnless.htm
355Fiero
Report this Post05-16-2012 06:12 PM Click Here to See the Profile for 355FieroSend a Private Message to 355FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks very much for the info.
I just picked up a '97 setup off a member here so I am good to go on the fuel rail and injectors. Now, as I get into this, I am sure I will start uncovering all the other stuff I need......
Already have the flywheel on its way, have a SPEC II clutch already, have the mounts and lower alt bracket, 3800 harness..... Only about 2-3 dozen things will show up now......
Thanks all
Don
hnthomps
Total ratings: 50
Report this Post05-16-2012 08:57 PM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wow;
Cheers
Don
Just to give you a visual idea as to how the engine can look, here is a 3800 SC Series III engine (converted from drive by wire) installed in an 88 Mera. This should be very similar to the F308 rebody you are wanting. I can also show you a stock 3800 SC Series II engine with a 3.4 pulley in an 87 Mera if that is beneficial.
Nelson
[This message has been edited by hnthomps (edited 03-14-2014).]
355Fiero
Report this Post05-16-2012 11:54 PM Click Here to See the Profile for 355FieroSend a Private Message to 355FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Nelson. The clean s/c looks nice. It does make a difference without the pipes running over the top for sure. This pic has nothing running over the top so I assume you removed the crossover pipes and refit them around the end of the s/c?
I have looked at a couple other SII pics that have the three pipes running across them and it doesn't look bad to me either. The look above is certainly nicer than the pipes though. I will see what I end up doing with the pipes once I get everything together. At least I have a fuel rail and injectors at a minimum though......
I appreciate the replies folks.
Don
revin
Total ratings: 234
Report this Post05-17-2012 08:48 AM Click Here to See the Profile for revinSend a Private Message to revinEdit/Delete MessageReply w/QuoteDirect Link to This Post
The pics are of aftermarket FUEL RAILS not a stock series 3 fuel rail.
There will be 1 tube going over the top of the blower for the series 3 rails. Look on clubgp.com for good deals on the rails.
TbirdMarc
Report this Post03-13-2014 03:32 PM Click Here to See the Profile for TbirdMarcClick Here to visit TbirdMarc's HomePageSend a Private Message to TbirdMarcEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would like to use one of these rails but can't find any. Does anyone know where to get them?
