  Radiator Fan Wont Work. Help!
Radiator Fan Wont Work. Help! by Fltstone
Started on: 05-13-2012 09:19 PM
Replies: 7 (820 views)
Last post by: Gall757 on 12-09-2014 09:22 PM
Fltstone
Report this Post05-13-2012 09:19 PM Click Here to See the Profile for FltstoneSend a Private Message to FltstoneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey Guys, I need some help getting my radiator fan to run. I've replaced the Relay and the fan switch. When I try to run a straight wire I blow fuses. I have powered the fan up using the battery so I know it works. I really don't know what to look for next. Any help will be very appreciated. Thanks.
Mike Gonzalez
Total ratings: 130
Report this Post05-13-2012 09:35 PM Click Here to See the Profile for Mike GonzalezSend a Private Message to Mike GonzalezEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do you have power at the relay with the key on ? Are all your fuses good ? Does the fan come on with the HVAC control in A/C position ? Will the fan come on if you touch the wire on the engine fan switch to ground ?
Fltstone
Report this Post05-14-2012 12:03 AM Click Here to See the Profile for FltstoneSend a Private Message to FltstoneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Power to the relay? Yes
All fuses Good? Yes
Does the fan come with HVAC? No
Will the fan come on when engine fan switch is grounded? No
Mike Gonzalez
Total ratings: 130
Report this Post05-14-2012 09:11 AM Click Here to See the Profile for Mike GonzalezSend a Private Message to Mike GonzalezEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you ground the green/white wire at the relay will the fan come on ?
Fltstone
Report this Post05-14-2012 05:17 PM Click Here to See the Profile for FltstoneSend a Private Message to FltstoneEdit/Delete MessageReply w/QuoteDirect Link to This Post
No, the fan does not run when I ground the green wire - white line.
Mike Gonzalez
Total ratings: 130
Report this Post05-14-2012 09:53 PM Click Here to See the Profile for Mike GonzalezSend a Private Message to Mike GonzalezEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hmmm, strange, is the ground off the relay grounded ?
Fierology
Report this Post12-09-2014 06:54 PM Click Here to See the Profile for FierologySend a Private Message to FierologyEdit/Delete MessageReply w/QuoteDirect Link to This Post
What did you find?
I have a similar problem.
Michael
Report this Post12-09-2014 09:22 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Note that this thread is 2 years old, so the OP may not be around. If you explain your problem, someone may be able to help.
