Click here to visit The Fiero Store | View all sponsors
  87 Steering boot replacement
87 Steering boot replacement by FieroFish
Started on: 05-10-2012 08:36 AM
Replies: 5 (67 views)
Last post by: FieroFish on 05-11-2012 12:53 PM
FieroFish
05-10-2012 08:36 AM Click Here to See the Profile for FieroFishSend a Private Message to FieroFishEdit/Delete MessageReply w/QuoteDirect Link to This Post
My steering boot on the drivers side has a small tear in it. How difficult is this to replace? Just wondering what is underneath the boot and how it comes off of the tie rod.
Thanks
Carver1
Total ratings: 60
05-10-2012 09:57 AM Click Here to See the Profile for Carver1Click Here to Email Carver1Send a Private Message to Carver1Edit/Delete MessageReply w/QuoteDirect Link to This Post
You have to remove the outer tie rod and the clamp on the bigger end of the boot. Then just wiggle it off. If you have any rust or grease built up on the tie rod, it will have to be scraped off to slide the boot off because the small end is a pretty tight fit. Be sure to mark where the nut is on the tie rod for reassembly, or get an alignment afterwards. If you are replacing both, the passenger side is a little trickier. You have the dampener to remove also.
11 Camaro SS/RS
86 Fiero GT
03 Silverado 3500 Duramax! (Stacked, Tuned, Mean as Hell)
07 Suburban LT2
09 Avalanche LT3
i'm sure i could fly a plane no problem.
masospaghetti
05-10-2012 11:18 AM Click Here to See the Profile for masospaghettiClick Here to Email masospaghettiSend a Private Message to masospaghettiEdit/Delete MessageReply w/QuoteDirect Link to This Post
^ What he said.
Would highly recommend the boots from TFS...the ones from the parts houses (including Rockauto) were completely wrong, no way they would fit. Good price, too. Steering boots
FieroFish
05-10-2012 12:34 PM Click Here to See the Profile for FieroFishSend a Private Message to FieroFishEdit/Delete MessageReply w/QuoteDirect Link to This Post
Will I need a tie rod end remover tool? or is it easily done without?
Spoon
05-10-2012 11:19 PM Click Here to See the Profile for SpoonClick Here to Email SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
You may need a Pickle-Fork. Not the one in moms good silver drawer :
http://www.amazon.com/Lisle...rk-Kit/dp/B0002SRG4S
Spoon
FieroFish
05-11-2012 12:53 PM Click Here to See the Profile for FieroFishSend a Private Message to FieroFishEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks
