Click here to visit The Fiero Store | View all sponsors
  Can't loosen the bolts on the back of the engine cradle
Can't loosen the bolts on the back of the engine cradle by JustinusMagnus
Started on: 04-19-2012 06:48 PM
Replies: 7 (185 views)
Last post by: JustinusMagnus on 04-20-2012 03:46 PM
JustinusMagnus
04-19-2012 06:48 PM Click Here to See the Profile for JustinusMagnusSend a Private Message to JustinusMagnusEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think the mounts in the frame for both the bolts on the back of the engine cradle have broken loose and I can't get the bolts out to drop the cradle. Has this happened to anyone else? Thanks
Mike Gonzalez
Total ratings: 128
04-19-2012 07:17 PM Click Here to See the Profile for Mike GonzalezClick Here to Email Mike GonzalezSend a Private Message to Mike GonzalezEdit/Delete MessageReply w/QuoteDirect Link to This Post
very common, you can either cut a hole in the side of the frame to replace/reweld the nuts, or take off the rear bumper and try to reach them through the frame.
JustinusMagnus
04-19-2012 07:36 PM Click Here to See the Profile for JustinusMagnusSend a Private Message to JustinusMagnusEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks alot I'll take a look first thing in the morning. It been too long since I've driven my car.
Mike Gonzalez
Total ratings: 128
04-19-2012 07:45 PM Click Here to See the Profile for Mike GonzalezClick Here to Email Mike GonzalezSend a Private Message to Mike GonzalezEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can try soaking them good with penatrating oil, but if they are already spinning you will still need to get to the back side of them.
84se2m4
04-19-2012 08:31 PM Click Here to See the Profile for 84se2m4Click Here to Email 84se2m4Send a Private Message to 84se2m4Edit/Delete MessageReply w/QuoteDirect Link to This Post
I just dropped my cradle today, loosened the bolts days ago. I hate having to patch and or cut so I took the rear metal impact bumper off and reached a wrench in and stuck it on the nut then proceeded to take the bolt out. You can put it back in this way too with no welding but mind you it will still spin so you may eventually have to do it all over again.
Total ratings: 266
04-19-2012 10:03 PM Click Here to See the Profile for Dennis LaGruaClick Here to Email Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can remove the rear fascia in about 30 minutes or less. It is not hard. This exposes the rear flange nuts that typically break loose from the spot welds and start spinning in the frame when rusted. We spray with PB Blaster, wait a few minutes, then grab those nuts with a faucet wrench and use an impact from below. Works every time. The front cradle bolts can be the real dogs when they rust to the bolts. We use an air chisel on them along the parting line to pry them away from the bolts so that they can be pushed out.
" THE BLACK PARALYZER" -87GT 3800SC Series III engine, custom ZZP Intercooler setup, 3.4" Pulley, Northstar TB, LS1 MAF, 3" Flotech Afterburner Exhaust, Autolite 104's, MSD wires, Custom CAI, 4T65eHD w. custom axles, HP Tuners VCM Suite.
RWDPLZ
Total ratings: 263
04-19-2012 10:42 PM Click Here to See the Profile for RWDPLZClick Here to visit RWDPLZ's HomePageSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
Mine were a PITA too, here's what they look like about 3/4 of the way down the page:
http://www.fiero.nl/forum/Forum2/HTML/121544.html
JustinusMagnus
04-20-2012 03:46 PM Click Here to See the Profile for JustinusMagnusSend a Private Message to JustinusMagnusEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just finished getting the engine and transmission out and apart. I ended up cutting and welding the nut back down.
