Click here to visit The Fiero Store | View all sponsors
  Dashboard Lights
Dashboard Lights by hckyplyr55
Started on: 04-19-2012 04:09 PM
Replies: 10 (303 views)
Last post by: masospaghetti on 04-24-2012 01:14 PM
hckyplyr55
04-19-2012 04:09 PM Click Here to See the Profile for hckyplyr55Click Here to Email hckyplyr55Send a Private Message to hckyplyr55Edit/Delete MessageReply w/QuoteDirect Link to This Post
The Dashboard lights in my Fiero dont work. The only thing that happens, when I turn on the headlights the clock on the dash goes off. When the headlamps are off the clock works. any opinions. Do anyone know where I can get a schematic for the electrical system, showing the relays?
hckyplyr55
04-19-2012 04:12 PM Click Here to See the Profile for hckyplyr55Click Here to Email hckyplyr55Send a Private Message to hckyplyr55Edit/Delete MessageReply w/QuoteDirect Link to This Post
It is a Pontiac Fiero GT V6 2.8 Liter
30+mpg
Total ratings: 94
04-19-2012 05:47 PM Click Here to See the Profile for 30+mpgClick Here to Email 30+mpgSend a Private Message to 30+mpgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check the service manual.
Download Factory Service Manuals here: http://www.fieronews.net/fusion/downloads.php
NightMare Cruiser
04-19-2012 06:28 PM Click Here to See the Profile for NightMare CruiserClick Here to visit NightMare Cruiser's HomePageSend a Private Message to NightMare CruiserEdit/Delete MessageReply w/QuoteDirect Link to This Post
blown fuse.
what kind of bulbs are you using?
dimmer relay blown?
http://www.fiero.nl/forum/Forum2/HTML/120126.html
hope this helps
hckyplyr55
04-19-2012 06:56 PM Click Here to See the Profile for hckyplyr55Click Here to Email hckyplyr55Send a Private Message to hckyplyr55Edit/Delete MessageReply w/QuoteDirect Link to This Post
@nightmarecruiser- the fuses are fine, we checked them. the bulbs are working good, we tested each one. possibly think the relay is bad or the switch is bad. thanks
seajai
04-19-2012 07:36 PM Click Here to See the Profile for seajaiClick Here to Email seajaiSend a Private Message to seajaiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check the dash lights dimmer for an open. The power is routed through the dimmer and then to the lights. The radio goes dark because the display is supposed to dim when you turn on the lights. My money is on the dimmer.
Bloozberry
04-19-2012 07:53 PM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
But before you do anything else, make sure the dimmer isn't turned all the way down.
Total ratings: 483
04-19-2012 08:45 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
see my cave, dimmer and others in lighting section.
mferrell
04-21-2012 08:10 AM Click Here to See the Profile for mferrellClick Here to Email mferrellSend a Private Message to mferrellEdit/Delete MessageReply w/QuoteDirect Link to This Post
I recently changed the cluster in mine and now have the same problem. It is in the printed circuit floppy thing on the back side of the cluster. so now I have to take it back apart and change that from my original cluster on to the one that all the gauges work. If you dont find the problem elsewhere you might check that out. you can take the cluster out, trace the circuit from the lights to the place where the plug goes to see if you put power to the right circuit if you get lights. remember to atach a ground at the plug also.
Spoon
04-22-2012 09:19 PM Click Here to See the Profile for SpoonClick Here to Email SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Your in good company. I had same problem several days ago. Discovered the dimmer wheel was not in the brightest position. Made it appear that the radio light went off when putting on the headlights.
Spoon
masospaghetti
04-24-2012 01:14 PM Click Here to See the Profile for masospaghettiClick Here to Email masospaghettiSend a Private Message to masospaghettiEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had the same issue when I got my Fiero and my gauges also didn't work. The electrical connectors to the dash circuit board were dirty and corroded, also the connections to the bulbs themselves were dirty. I cleaned them up real nice and all is good now.
