  TPS sensor voltage reading 14% at closed throttle idle after harness rebuild
TPS sensor voltage reading 14% at closed throttle idle after harness rebuild by Joseph Upson
Started on: 03-24-2012 10:22 AM
Replies: 15 (4406 views)
Last post by: hookdonspeed on 11-15-2013 08:59 AM
Joseph Upson
Total ratings: 88
Report this Post03-24-2012 10:22 AM Click Here to See the Profile for Joseph UpsonSend a Private Message to Joseph UpsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rewired harness to clean things up and now TPS sensor reads 14% at idle.
The car cranked and idled fine with a typical TPS reading of .34%. After the fourth start or so the TPS reading jumped to 14% for no apparent reason.
The only way I can get the sensor to read 0% in the datalog is to unbolt it and turn it clockwise a little. It's as if the throttle blade is cracked open but it's not and the sensor is not adjustable except for what the idle screw can exact.
Any ideas before I start hacking up the harness that took too long to finish in the first place.
3900 V6 aluminum heads. Cadillac throttlebody which is similar to the 3x00 throttlebodies just bigger. I tried a different computer and a different sensor and ended up with the same result.
[This message has been edited by Joseph Upson (edited 03-24-2012).]
Total ratings: 290
Report this Post03-24-2012 11:15 AM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
IF the sensor reads 0 unbolted and turned to it's full travel, the problem is NOT with the wiring.
[This message has been edited by phonedawgz (edited 03-24-2012).]
Joseph Upson
Total ratings: 88
Report this Post03-24-2012 11:27 AM Click Here to See the Profile for Joseph UpsonSend a Private Message to Joseph UpsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I hope you are correct, I had to consider a possible issue with ground arrangement or some kind of induction interference, which in theory would not go away with repositioning of the sensor. Some how I don't think it's that simple.
Marvin McInnis
Total ratings: 227
Report this Post03-24-2012 01:01 PM Click Here to See the Profile for Marvin McInnisClick Here to visit Marvin McInnis's HomePageSend a Private Message to Marvin McInnisEdit/Delete MessageReply w/QuoteDirect Link to This Post
I agree. The ECM "learns" the throttle-closed voltage from the TPS every time you start the car and then rescales from there. As long as the ECM "knows" that 0.7 volts (14% of 5 volts) currently equals closed throttle, there should be no problem. Properly installed, the TPS voltage with the throttle butterfly fully closed should always be somewhat above zero.
[This message has been edited by Marvin McInnis (edited 03-24-2012).]
firejo24
Report this Post03-24-2012 01:16 PM Click Here to See the Profile for firejo24Send a Private Message to firejo24Edit/Delete MessageReply w/QuoteDirect Link to This Post
Check your 5 VDC reference and ground at the TPS. If the voltage is low or the ground isn’t good it will change the reading back to the ECM.
Joseph Upson
Total ratings: 88
Report this Post03-24-2012 01:30 PM Click Here to See the Profile for Joseph UpsonSend a Private Message to Joseph UpsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, it was normally .34% and the ECM's response to TPS input depends on the programming. Remember that the ECM reads throttle position to determine whether it should be adding fuel or pulling fuel at startup as well as state of throttle input such as in clear flood mode use.
What immediately made this a problem is the engine idle, which is around 1300 with the TPS sensor reading that high at startup, so it's a little more complicated than just a position reference.
The weird thing about it is when I offset the sensor to 0 the TPS % stays at 0 until the throttle is opened enough to give the impression that it is overly delayed suggesting it is okay to return the sensor to its proper position, only when I do it reads 14% at closed throttle again. There is also a stumble on rapid acceleration from idle that corasponds with the delayed pump shot that results from the repositioning. I don't want to rescale the table to compensate I'd like to find and fix the problem.
It may be that both sensors are bad since I don't know the history on the other. I just hate the idea of throwing away $40 on something I may not need. Right now it appears the sensor is the problem because when it's unplugged the datalog shows 0%.
Thanks for the input, I'm glad I don't know everything because I'd have no one to go to with my problems if I did.
Marvin McInnis
Total ratings: 227
Report this Post03-24-2012 04:21 PM Click Here to See the Profile for Marvin McInnisClick Here to visit Marvin McInnis's HomePageSend a Private Message to Marvin McInnisEdit/Delete MessageReply w/QuoteDirect Link to This Post
Also consider that the TPS is only used by the ECM when its value is changing. At constant throttle the TPS has no effect at all on fuel delivery or spark timing.
firejo24
Report this Post03-24-2012 04:43 PM Click Here to See the Profile for firejo24Send a Private Message to firejo24Edit/Delete MessageReply w/QuoteDirect Link to This Post
The reality is that you don’t really know anything unless you know for sure that you’re getting the full 5 vdc and a proper ground. Garbage in garbage out.
Joseph Upson
Total ratings: 88
Report this Post03-24-2012 05:03 PM Click Here to See the Profile for Joseph UpsonSend a Private Message to Joseph UpsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I appreciate the input guys but I'm not new to diagnosing problems of this nature and so far the fundamentals have been verified physically or at least are registering in the data as proper.
This does not seem to be the case at the moment. As I stated earlier, if the sensor is installed in its proper position where it is for some reason registering 14% in the datalink now, I promise you the engine will idle at approximately 1300 rpm and that's without any throttle movement. Unplug the TPS or offset it to 0 and idle returns to normal. I'm running 8F code mask. Your statement is partially correct as there are asynchronus multiplication factors that vary with the position of the throttle and directly affect fueling even if the throttle is at steady state and that's probably not the only table association with that kind of variance.
Although I have not measured it physically, the datalink consistenly shows 100% with the throttle to the floor, I doubt a voltage measurement is necessary in this case.
I installed a new sensor and received the same result and I was expecting it based on what I've done so far.
The only other possibility I can think of now as being a clue is that the vehicle speed signal is jumpy. I use a Dakota Digital and need to go back and twist the sensor wires. If the odometer needle starts to twitch at idle the rpm goes up in that scenario as well. There was no problem with the odometer stability previously.
My plan now if I can find the time before work tomorrow is to pull the harness, go over the grounds again and back probe the harness again to make sure everything is connected where it should be.
Total ratings: 463
Report this Post03-24-2012 05:17 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
The only time I have ever seen a really wonky TPS voltage is when I had mine mis-wired.
FWIW, the 4.9 TPS uses the center pin on the connector as the wiper. The Allante TPS (which looks more like a stock Fiero connector) has the wiper on one end.
It seemed to have a stumble when I hammered it, and the tranny didn't have a clue about when to shift.
[This message has been edited by Raydar (edited 03-24-2012).]
Joseph Upson
Total ratings: 88
Report this Post03-24-2012 05:36 PM Click Here to See the Profile for Joseph UpsonSend a Private Message to Joseph UpsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's a possibility, the pin assignment for the Fiero vs. the TGP sensor is different, it's possible I strayed and looked at the wrong diagram since I had them both out. I also recall a misprint in one of the diagrams I have some time ago involving either the TPS or the MAP sensor. The sensor read .34% on the first few starts and then suddenly jumped to 14% and has been there since. I'll do a harness by pass wiring directly into the ECM and see what happens.
stickboy
Report this Post03-26-2012 01:16 PM Click Here to See the Profile for stickboySend a Private Message to stickboyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is the 1300RPM idle higher than usual? Is so, my first thought would be that if the idle is high, and the TPS reading is high, then the throttle body is open a little bit more than usual....
Joseph Upson
Total ratings: 88
Report this Post03-26-2012 05:06 PM Click Here to See the Profile for Joseph UpsonSend a Private Message to Joseph UpsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks but that falls under the common sense catagory for those of us that have a good understanding of the sensor function. I mentioned in the first thread that the TPS reading was a sudden and drastic change from normal at idle/ closed throttle.
One thing is for sure, TPS function as a steady state/acceleration monitor is much more sophisticated than the thought that it sets a reference point at power on and then adjusts from there. The unsynchronized voltage output relative to throttle position threw off the entire fuel map. It caused a high idle with the abnormally high reading at closed throttle as well as a rich condition.
When I offset it to restore a 0% reading at closed throttle it was a little too far retarded prolonging the 0% reading, or more clearly, a lower % throttle open reading than what it should which obviously leaned out the fuel map.
The above was observed in the datalog.
3 sensors, and two computers along with checking the harness and making the grounds more direct with fewer combined links all grounding at the same location on the cylinder head and that still didn't correct it. I finally slotted the bolt holes on the sensor to make it adjustable which allowed me to restore a proper reading at closed throttle.
Joseph Upson
Total ratings: 88
Report this Post11-12-2013 09:55 PM Click Here to See the Profile for Joseph UpsonSend a Private Message to Joseph UpsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
To bring this problem to a close, I never did figure out what caused the high off throttle voltage but it was a problem in the harness that caused it. The problem resolved with a new harness and if I had to take a guess I would say a ground arrangement was the culprit as some grounds go directly to chassis/engine and some go straight to the ECM and I probably crossed one up in the previous harness.
lou_dias
Report this Post11-14-2013 08:45 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is the same problem I'm having on my 4.9 w/Allante intake. Except mine reads 66% (1.12v) closed and goes to 4.87v at WOT. The Allante TPS is supposed to be .5v-3v :/
Yes I verified the inputs. Yes I switched the wiring. My idle is also higher than it should be. I was thinking of installing a voltage divider circuit...except I don't know the resistance to the ECM in order to attempt to build it.
hookdonspeed
Total ratings: 131
Report this Post11-15-2013 08:59 AM Click Here to See the Profile for hookdonspeedClick Here to visit hookdonspeed's HomePageSend a Private Message to hookdonspeedEdit/Delete MessageReply w/QuoteDirect Link to This Post
check the sensors resistance value... ALOT of the 'china' sensors do NOT put the voltages where they should be :/
