  Door lock replacement
Door lock replacement by Paulys84SE
Started on: 08-09-2010 07:37 PM
Replies: 14 (5293 views)
Last post by: mrfred8 on 11-05-2014 10:17 PM
Paulys84SE
Report this Post08-09-2010 07:37 PM Click Here to See the Profile for Paulys84SESend a Private Message to Paulys84SEEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi,
Can someone tell me how to replace the drivers side door lock on a 84 Fiero?
I removed the door panel and the linkage but cant figure out how to remove the lock. Does it come out from the outside or inside the door. Do you need a special tool.
Thanks, Steve
Mike Gonzalez
Total ratings: 130
Report this Post08-09-2010 08:41 PM Click Here to See the Profile for Mike GonzalezSend a Private Message to Mike GonzalezEdit/Delete MessageReply w/QuoteDirect Link to This Post
You need to remove the outer doorskin. The lock cylinder is held in by a clipe slid behind the metal brace on the skin.
Cajun
Report this Post08-09-2010 08:47 PM Click Here to See the Profile for CajunSend a Private Message to CajunEdit/Delete MessageReply w/QuoteDirect Link to This Post
I replaced both door locks on my GT about a year ago. I did not remove the outter skin. I was able to get to and remove the retaining clip that holds the lock cylinder in place. Once the clip is removed the cylinder will come out. Don't forfet about the weather foam washer between the outter skin and the lock cylinder. More times than not when removing the door lock it will fall out without you noticing.
Good luck.
Paulys84SE
Report this Post08-09-2010 08:53 PM Click Here to See the Profile for Paulys84SESend a Private Message to Paulys84SEEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Mike
Any advice on removing the door skin. Looks like it is held on with phillup screw faseners.
Thank you Steve
Mike Gonzalez
Total ratings: 130
Report this Post08-09-2010 09:05 PM Click Here to See the Profile for Mike GonzalezSend a Private Message to Mike GonzalezEdit/Delete MessageReply w/QuoteDirect Link to This Post
I tried with no luck for hours to get the retaining clips off without removing the skins. Once I removed them it was easy.
They are held on with the "phillips" plastic screws front and rear. If they strip out it is a 10mm bolt head under the plastic if you break the plastic away. There are rivits at the bottom of the door the need drilled out. And the moulding needs romoved, if you can reach and squeeze the clips from inside you may be able to reuse them. There is a little push rivet under the door handle, and a 7mm screw at the front of the door once the moulding is off. The top of the skin on 84's is held by thos "Christmas Tree" fasteners.
Dodgerunner
Total ratings: 323
Report this Post08-09-2010 11:01 PM Click Here to See the Profile for DodgerunnerClick Here to visit Dodgerunner's HomePageSend a Private Message to DodgerunnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
they actually come out the inside but as said above you have to pull the clips that hold them in. Due to the area you have to work in it's not to easy since the glass is in the way. This is what you see from inside the door.
and
Apart.
bjc 350
Report this Post08-09-2010 11:39 PM Click Here to See the Profile for bjc 350Send a Private Message to bjc 350Edit/Delete MessageReply w/QuoteDirect Link to This Post
I've changed several sets without taking the skin off. When putting in the new lock, I first drilled a hole in the retaining clip and tied a nylon string to it. Because, when you inevitably drop it into the door, you can retrieve it with fewer cuss words. It is one of the" less fun" projects on a Fiero.
Larryh86GT
Report this Post08-10-2010 06:54 AM Click Here to See the Profile for Larryh86GTSend a Private Message to Larryh86GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
That is a great idea. I've dropped them a dozen or so times and it gets not so funny after a while. There is just enough room to squeeze your hand in from the inside to do the removal and replacement of the clip but your hand does take a beating do this. When I did my locks this past spring the PO had one of the retainer clips in backwards with the pull tab on it facing away from me. I had to drill a hole in it to be able to stick something in it to pull it off the lock.
"Life is short.
Drink the good wine first"
ltlfrari
Total ratings: 127
Report this Post08-10-2010 11:54 AM Click Here to See the Profile for ltlfrariClick Here to visit ltlfrari's HomePageSend a Private Message to ltlfrariEdit/Delete MessageReply w/QuoteDirect Link to This Post
See my web site, link in sig below.
Fierology
Report this Post08-10-2010 12:13 PM Click Here to See the Profile for FierologySend a Private Message to FierologyEdit/Delete MessageReply w/QuoteDirect Link to This Post
ltlfrari, you missed your sig.
-Michael
ltlfrari
Total ratings: 127
Report this Post08-10-2010 10:07 PM Click Here to See the Profile for ltlfrariClick Here to visit ltlfrari's HomePageSend a Private Message to ltlfrariEdit/Delete MessageReply w/QuoteDirect Link to This Post
oops....
Dave
www.ltlfrari.com
Robert 2
Report this Post08-02-2011 09:33 AM Click Here to See the Profile for Robert 2Send a Private Message to Robert 2Edit/Delete MessageReply w/QuoteDirect Link to This Post
very good
GADJet
Report this Post02-26-2013 10:13 PM Click Here to See the Profile for GADJetSend a Private Message to GADJetEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is high on the priority list for me to do once the weather warms a little. Thanks for the suggestions posted above.
James Bond 007
Total ratings: 263
Report this Post02-26-2013 10:48 PM Click Here to See the Profile for James Bond 007Send a Private Message to James Bond 007Edit/Delete MessageReply w/QuoteDirect Link to This Post
Your going to need a big screw driver to tap that big C Clip out.
If you have power door locks,Grease the plastic clip that supports the rod. Your door or doors will open much easyer.
mrfred8
Report this Post11-05-2014 10:17 PM Click Here to See the Profile for mrfred8Click Here to visit mrfred8's HomePageSend a Private Message to mrfred8Edit/Delete MessageReply w/QuoteDirect Link to This Post
and
Apart.
Thanks for the pictures. I was able to get mine out , got a key made, and put back in without removing the door skin or trim.
