Click here to visit The Fiero Store | View all sponsors
  Multi (8) throttle body Northstar! (Page 4)
This topic is 9 pages long:  1   2   3   4   5   6   7   8   9
Author Topic:   Multi (8) throttle body Northstar!
xunedeinx
12-27-2007 02:00 AM Click Here to See the Profile for xunedeinxClick Here to Email xunedeinxSend a Private Message to xunedeinxEdit/Delete MessageReply w/QuoteDirect Link to This Post
Negative, that sound clip is This...
http://youtube.com/watch?v=Ba8sT2BQ4uc
Erik
Total ratings: 173
12-27-2007 02:17 AM Click Here to See the Profile for ErikClick Here to Email ErikSend a Private Message to ErikEdit/Delete MessageReply w/QuoteDirect Link to This Post
HMMM ..how the hell did that get on this thread? I bet Russ Northstar sounds very much like that. Anyway, the 1UZ would make one hell of a Fiero engine swap
Russ544
Total ratings: 85
12-27-2007 11:11 AM Click Here to See the Profile for Russ544Send a Private Message to Russ544Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by cptsnoopy:
Congrats Russ,
If you find that your system works to your satisfaction, can you post a required parts list?
Erik, just wondering what you have been smoking? I can't seem to get that sound bite on my computer...
Hi Charlie. good to hear you're still alive and kicking. the second job hasn't killed you off yet afterall then?
ITB parts list:
2 06-07 Suzuki GSXR 600 throttle body assy.
2 4" block of aluminum (one for iac valve block and one for tps adaptor)
1 4" steel tube for throttle shaft extensions
1 various scraps of steel for brackets
8 13/4" mandrel bent exhaust tubing (45*)
2 3" x 18" x 1/4" plate steel
1 lathe
1 milling machine
1 mig welder
1 oxy acetalyn welder
1 plazma cutter
80 hours of free time
hope this helps
Russ
PS: oh ya,... I'll have one of what Eric has also
[This message has been edited by Russ544 (edited 12-27-2007).]
Russ544
Total ratings: 85
12-27-2007 11:27 AM Click Here to See the Profile for Russ544Send a Private Message to Russ544Edit/Delete MessageReply w/QuoteDirect Link to This Post
Eric. I have no idea why you're hearing the sound clip. it was posted earlier on this thread however.
my current exhaust system consists of a piece of sewer pipe slipped over the Y pipe, just off the headers, and then stuck out a hole I cut in the shop wall. no muffler. when I first fired it up my first thought was "drag boat engine". no doubt the exhaust system has a lot to do with that, but it dose actually sound a lot like some alchol drag boats that I've heard. very quick reving (flex plate and no clutch weight helps there). somewhat more "American" than that sound clip, but no muscle car drone. I'll work on a place to post a clip in the next day or two. I'm kinda busy right now. Ahrrrr Ahrr Ahrr....
Russ
Erik
Total ratings: 173
12-27-2007 01:32 PM Click Here to See the Profile for ErikClick Here to Email ErikSend a Private Message to ErikEdit/Delete MessageReply w/QuoteDirect Link to This Post
Russ
That must explain why I heard it. I have no idea why it would play while I am typing up a reply though
motoracer838
Total ratings: 70
12-27-2007 01:45 PM Click Here to See the Profile for motoracer838Click Here to Email motoracer838Send a Private Message to motoracer838Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Erik:
http://home.mchsi.com/~hous...kowitz/Northstar.wav
Is this your engine Russ? When I click on post reply in your thread and start typing this comes up on my speakers
Oh My Gawd, that sounds INSANE!!! Great just one more thing my northstar project needs.
Somehow Cheers Beers n Gearz just doesn't cut it. Joe
Russ544
Total ratings: 85
12-27-2007 02:18 PM Click Here to See the Profile for Russ544Send a Private Message to Russ544Edit/Delete MessageReply w/QuoteDirect Link to This Post
Joe. your Northstar does need one.... but that's not the sound of my engine. I'll post one of mine soon if I can get a decent rendition on my digi cam.
The only place this block is going it to the scrap yard to be melted down to make a few thousand beer cans (I could use a few full ones myself right now). I took a closer look at the crack today, and marked along side it with a felt tip pen so it shows up in the pic (although the water has made it easier to see now anyway):
Ya... that could be welded I guess........ if that was the end of the crack:
I still can't believe I didn't see this a long time ago [ouch... ouch... ouch... kicks self in butt]
I do have another block, so I could take the guts out of this motor and put them into that block (the one that was missing 2 rod caps and some main bolts)..... or.. a guy is supposedly bringing me a 96 long block that leaked oil at the lower case seal (free). ....... Northstars seem to be kinda like Fieros in that once people find out you like them.... they want to, or know someone who wants to, give you more of them .
Rickady88GT
Total ratings: 129
12-27-2007 02:24 PM Click Here to See the Profile for Rickady88GTClick Here to Email Rickady88GTSend a Private Message to Rickady88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Hudini:
Aluminum engine? Weld that baby! You have to pre-heat aluminum before welding anyways so it will boil away any water. If you can TIG weld you are in business. Otherwise, a good welder should be able to lay a pretty TIG weld. I use MIG and it is not so pretty but gets the job done.
Nice work on the ITB's.
Not as easy as it sounds sometimes. The NorthStar uses the pink coolant, Dex-cool. That stuff gets deep into the poors of the aluminum and will contaminate the weld, badly. Just welding the Tstat housing for my Short Star swap took an unbelievable amount of cleaning, heating, baking, welding, re-welding, grinding....on and on. If I had a crack in the block and had to go thru all that to weld it, I would just get a new or good used block and scrap the cracked one.
cptsnoopy
Total ratings: 55
12-27-2007 04:06 PM Click Here to See the Profile for cptsnoopyClick Here to Email cptsnoopySend a Private Message to cptsnoopyEdit/Delete MessageReply w/QuoteDirect Link to This Post
ITB parts list:
1 lathe
1 milling machine
1 mig welder
1 plazma cutter
hope this helps
Russ
Hey, Thanks Russ!,
Crap, I can come up with only a few of those parts... I am definitely out of it when it comes to the really nice goodies such as the lathe, milling machine and plasma cutter.
I will have to stick with the stock setup for now I guess.
Sorry to see that the block is not usable. I wonder how it got that way...
[This message has been edited by cptsnoopy (edited 12-27-2007).]
Russ544
Total ratings: 85
12-27-2007 06:11 PM Click Here to See the Profile for Russ544Send a Private Message to Russ544Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hey, Thanks Russ!,
It's much too early to speculate, but two (local) people have been watching my progress and have shown an interest in having me build them one. It might be cheeper for you to buy a lathe, milling machine and plasma cutter, but it is a real possibility that I could build a couple more. I have a couple ideas that would make the next ones a little easier/cheeper to build, and certainly more refined, but it still requires a LOT of labor (which equals money).
as to the cracked block, I got this one from a guy who had it sitting in an old shed with a 1/2 dozen other engines. it must have sat on end with #7 down, got water in it, and froze (that happens in some parts of the country you know ). I guess it's a slim posibility that it could have cracked during a wreak, but it seems less likely. I just put a coat of JB Quik on the crack, and that should allow me to still use this engine as a test mule, as long as I use a low presure rad cap.
30+mpg
12-27-2007 08:12 PM Click Here to See the Profile for 30+mpgClick Here to Email 30+mpgSend a Private Message to 30+mpgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do your other spare blocks have any cracks?
Russ544
Total ratings: 85
12-28-2007 12:33 PM Click Here to See the Profile for Russ544Send a Private Message to Russ544Edit/Delete MessageReply w/QuoteDirect Link to This Post
Actually... the question should be: If I end up going that route, do you think I'll check it for cracks before begining work on it?
Russ544
THE BEAST
12-28-2007 01:47 PM Click Here to See the Profile for THE BEASTClick Here to Email THE BEASTSend a Private Message to THE BEASTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Very nice, I'm waiting for the clip!
JG
Russ544
Total ratings: 85
12-28-2007 04:24 PM Click Here to See the Profile for Russ544Send a Private Message to Russ544Edit/Delete MessageReply w/QuoteDirect Link to This Post
JG
Well. lets see if this works:
http://www.youtube.com/watch?v=nhoAR3UfLRo
motoracer838
Total ratings: 70
12-28-2007 04:30 PM Click Here to See the Profile for motoracer838Click Here to Email motoracer838Send a Private Message to motoracer838Edit/Delete MessageReply w/QuoteDirect Link to This Post
Allright, that will be enough of that, it's bad enough that I want to sell my CHRFAB flywheel and get one of the aluminum units from firdanza!!!
That sounds awsome.
Joe
Total ratings: 128
12-28-2007 04:31 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Very Nice!!!!
Now you can make me one for my SBC!
Russ544
Total ratings: 85
12-28-2007 04:51 PM Click Here to See the Profile for Russ544Send a Private Message to Russ544Edit/Delete MessageReply w/QuoteDirect Link to This Post
how do you get the Youtube screen on this site? I ended up just doing a cut and paste of the url, and that works I guess.... but.
Guru, what is a "sbc"? Joe, I'll start on yours soon
Russ544
Erik
Total ratings: 173
12-28-2007 04:58 PM Click Here to See the Profile for ErikClick Here to Email ErikSend a Private Message to ErikEdit/Delete MessageReply w/QuoteDirect Link to This Post
[This message has been edited by Erik (edited 12-28-2007).]
Erik
Total ratings: 173
12-28-2007 05:02 PM Click Here to See the Profile for ErikClick Here to Email ErikSend a Private Message to ErikEdit/Delete MessageReply w/QuoteDirect Link to This Post
Russ544
I tried to embed it for you but it doesn't work
Russ544
Total ratings: 85
12-28-2007 08:04 PM Click Here to See the Profile for Russ544Send a Private Message to Russ544Edit/Delete MessageReply w/QuoteDirect Link to This Post
ah HA. you need the brackets and "youtube' before and after the url to get the player window. here we go:
Russ544
[This message has been edited by Russ544 (edited 12-28-2007).]
cptsnoopy
Total ratings: 55
12-28-2007 09:28 PM Click Here to See the Profile for cptsnoopyClick Here to Email cptsnoopySend a Private Message to cptsnoopyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi Russ,
If you going to make a small run of these, I am interested. Do you see any issues with AZ emissions? Do you think it will be street friendly using the Holley? PM me when and if you decide to make a few and let me know how much to start saving up.
Just curious what your idle rpm is in the video?
charlie
Russ544
Total ratings: 85
12-29-2007 12:07 AM Click Here to See the Profile for Russ544Send a Private Message to Russ544Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hi Russ,
charlie
So you still plan to run with the Holley ecm? I'll keep that in mind. Because of my "cooling issues" , I haven't had a chance to run the thing closed loop yet, but when I was using the holley on the IMSA with the stock intake, it never idled as good as it does now with the itb setup. I'm running with the same base map that I developed for it before (which wasn't perfect by any means), and I haven't even plugged in the laptop to it yet to see where it's at with the ITBs. I did pull a plug out of #7 to check for water (none), and noted that it was running a bit rich now. what do you need for Az emissions? just a sniff test? I don't see any problem running this on the street other than air filtration issues and the like. I plan to make an air box for mine, but that wouldn't be a part of the package that I would make for others. As I stated before, it's still a little premature to say if or when I'll make more of these. a lot depends on how my future testing goes, and how well it performs in actual street trim, but I'll be working on that very soon. save up $4,500.oo or so, but you may not need it all. I'll let you know more on that later.
edit: I haven't checked the idle rpm yet, but it sounds like 800 or so. One reason I let it idle a few second on the vid clip, between blips, was for the benifit of those here who have prior experience with the holley, and it's idle quirks
Russ544
[This message has been edited by Russ544 (edited 12-29-2007).]
THE BEAST
12-29-2007 01:27 AM Click Here to See the Profile for THE BEASTClick Here to Email THE BEASTSend a Private Message to THE BEASTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Very nice Russ, and by the way are you running the exhaust with a pipe out of your garage ?
Boy now you can really use a set of equal length headers, but make no mistakes this intake is the way to go!
JG
cptsnoopy
Total ratings: 55
12-29-2007 03:32 AM Click Here to See the Profile for cptsnoopyClick Here to Email cptsnoopySend a Private Message to cptsnoopyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Russ544
Hi Russ,
If your setup is running good and is street drivable using A/C (don't see why not) with the Holley950 then yes I would keep the Holley. Your setup would allow me to run the Transmission shift cables in their stock position as I could just make a "Y" that went around them to two plenums. We need whatever emissions items that are on the stock 88 Fiero when it was produced. I would most likely have to "dummy" the egr but the rest should work. Then of course we get the sniff test.
I would make my decision based on your testing and recommendations but it does look promising.
Charlie
Gokart Mozart
Total ratings: 121
12-29-2007 09:34 AM Click Here to See the Profile for Gokart MozartClick Here to visit Gokart Mozart's HomePageSend a Private Message to Gokart MozartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Have you seen http://www.chrfab.com/Engines.htm
Russ544
Total ratings: 85
12-29-2007 11:39 AM Click Here to See the Profile for Russ544Send a Private Message to Russ544Edit/Delete MessageReply w/QuoteDirect Link to This Post
you betcha. Alan is a nice guy and very knowledgable on N* goodies, although he seems to be branching out more in other dirrections these days. I sent him a link to this thread when it began, so I need to remind him to look again to see the "success video" .
Thanks,
Russ544
Russ544
Total ratings: 85
12-29-2007 01:13 PM Click Here to See the Profile for Russ544Send a Private Message to Russ544Edit/Delete MessageReply w/QuoteDirect Link to This Post
JG
wy wout i rout it 73t5ut otsid? fums never boterd me bafore.
Ya... I have a pipe going out a hole in the shop wall. it's a finely tuned system . actually I just got a package from FedX that should be a cheepy muffler from Summit, so I can ease my guilt wile tuning at midnight (nearest neighbor is 100 yards away however). equal length header on a Northstar? in a Fiero? that might be a challenge even I wouldn't take ha ha.
Russ544
Russ544
Total ratings: 85
12-29-2007 01:19 PM Click Here to See the Profile for Russ544Send a Private Message to Russ544Edit/Delete MessageReply w/QuoteDirect Link to This Post
That's a nice side benifit for you and I, of using the ITB isn't it ? I thought of that as well. the Isuzu trans N* might become more common now
For those that may be wondering what the heck we're talking about. CptSnoopy is working on his N* installation, and plans to use an Isuzu trans with it. I used an Isuzu on my swap as well, but we may well be the only two that have them. everyone said it couldn't be done, due mostly to the way the shift cables exit this trans, and run right into the stock N* throttle body. I built bellcranks for mine (see "in progress" pic from my build, below), and I think the Cpt was planning a similar stratagy. with the ITB injection, however, this particular problem now becomes a non issue.
[This message has been edited by Russ544 (edited 12-30-2007).]
AJxtcman
12-29-2007 10:00 PM Click Here to See the Profile for AJxtcmanClick Here to Email AJxtcmanSend a Private Message to AJxtcmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Russ544
I am giving it a try. When I quoted you it came up as text.
[This message has been edited by AJxtcman (edited 12-29-2007).]
MclarenF1
12-29-2007 10:01 PM Click Here to See the Profile for MclarenF1Click Here to visit MclarenF1's HomePageClick Here to Email MclarenF1Send a Private Message to MclarenF1Edit/Delete MessageReply w/QuoteDirect Link to This Post
You may have to send me a test subject so I can make sure it fits with the isuzu. I might just "have" to go the ITB route. DARN!
AJxtcman
12-29-2007 10:05 PM Click Here to See the Profile for AJxtcmanClick Here to Email AJxtcmanSend a Private Message to AJxtcmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Russ544
I have been reading this since the beginning and that is the best part. Yeah the 8 t-bodies are cool also
THE BEAST
12-29-2007 11:16 PM Click Here to See the Profile for THE BEASTClick Here to Email THE BEASTSend a Private Message to THE BEASTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Russ544
I thought there were "just some" key notes missing in that clip...
JG
Russ544
Total ratings: 85
12-29-2007 11:58 PM Click Here to See the Profile for Russ544Send a Private Message to Russ544Edit/Delete MessageReply w/QuoteDirect Link to This Post
Like the sign in my business says: "INTEREST FREE CREDIT - 100% down - no payments".
you are aware that some work is also required on the clutch throw out fork in order to use the Isuzu.... right? The ITB will help a bunch, but it's still not a bolt on and go proposition. If you're serious about the ITB, I'll put you on the list to keep updated.
Russ544
Russ544
Total ratings: 85
01-05-2008 04:32 PM Click Here to See the Profile for Russ544Send a Private Message to Russ544Edit/Delete MessageReply w/QuoteDirect Link to This Post
Just a short progress report:
I've begun building more, and more precise, jigs in order to build a few more of the ITB setups. These are the major jigs (the new ones) used to build the manifold itself.
The top left piece aligns the injector bungs wile being welded in place. the piece on the right holds the mandrel bends so the individual tubes can be cut. and the bottom piece helps hold the top of each manifold tube in alignment wile it's being welded into the flange (hardware not shown).
several people have come forward and want me to build one of these for them. I'll only have time to build a few a year, but I'm working on ways to make them more affordable, more uniform, higher quality, and quicker to build. the jigs are one way to help that process along. I'm also working on ways to lessen the amount of machine work needed, and have made some progress on that front. a local guy is working on a bid for me to water jet cut the flanges, and I currently have enough parts ordered to build two more compleat setups + some. after I build one or two more I should have a pretty good idea what I'll have to charge for them. I'm not looking to get rich off this deal, but there IS a LOT of labor involved, so they won't be cheep either. As always, I'll keep you posted.
Russ544
It's just like building a canoe out of a log. first you cut down a tree........ then you cut off everything that doesn't look like a canoe.
[This message has been edited by Russ544 (edited 01-05-2008).]
ryan.hess
Total ratings: 315
01-05-2008 06:15 PM Click Here to See the Profile for ryan.hessClick Here to Email ryan.hessSend a Private Message to ryan.hessEdit/Delete MessageReply w/QuoteDirect Link to This Post
sweet....... can't really tell what it sounds like.... it's got a v8 rumble and then it sounds like a race bike
ALLTRBO
01-05-2008 07:42 PM Click Here to See the Profile for ALLTRBOSend a Private Message to ALLTRBOEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sweet!
Whoever said "Keep it simple, stupid" must never have heard an ITB'd Northstar.
I'd be happy with only 4 of those TB's on my carb'd 1100, let alone 8 on a real engine. Too many projects, too little time.
Formula88
Total ratings: 481
01-06-2008 03:55 PM Click Here to See the Profile for Formula88Send a Private Message to Formula88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Russ544
That's awesome! I can't wait to see the completed car.
ryan.hess
Total ratings: 315
01-06-2008 04:31 PM Click Here to See the Profile for ryan.hessClick Here to Email ryan.hessSend a Private Message to ryan.hessEdit/Delete MessageReply w/QuoteDirect Link to This Post
I forgot, you probably just have the stock flexplate on there? I bet once you slap on a 20# flywheel (or torque converter as the case may be) it won't be nearly as rev happy.
Russ544
Total ratings: 85
01-06-2008 05:37 PM Click Here to See the Profile for Russ544Send a Private Message to Russ544Edit/Delete MessageReply w/QuoteDirect Link to This Post
True. however I've run my stock intake Northstar with only the flexplate also, and this setup does seem to have a snappier throttle response. but then again.... the ITB setup has a very different sound to it. especially at mid rpm - light loads. Each pair of intake valves closing, in their own runner, makes a very unusual pulsing... or kind of "buzzing" sound. kind of the sound a formula 1 car makes when it hits the rev limiter, except when when the Northstar makes that sound, at around 2,500 to 3,500 rpm, it can still rev higher.
[This message has been edited by Russ544 (edited 01-07-2008).]
Russ544
Total ratings: 85
01-06-2008 05:52 PM Click Here to See the Profile for Russ544Send a Private Message to Russ544Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks ! If you mean the 36' Ford, that project is on hold, now that my "spare" Northstar was found to have a cracked block. It will still get done, but it may be a wile. meanwile I plan to build a 2nd generation (very similar but nicer) intake manifold for this ITB and install it on the Northstar that's already in my IMSA. that way I can get some road time on it, as well as checking the compatability of the ITBs with the 7730 ECM (Ryans setup) that's currently in use in this car.
Russ544
[This message has been edited by Russ544 (edited 01-06-2008).]
Administrative Options: Close Topic | Archive/Move | Delete Topic | Top
