Author
Topic: Unique engine swap in my '88 GT
AJ7 Member Posts: 3562 From: NE Registered: Sep 2005
update?IP: Logged |
Emc209i Member Posts: 3091 From: Charlotte, NC Registered: Apr 2005
Total ratings: 225
You know those Sparco seats would look good in a running car... LOOK THERE GOES ANOTHER CARRIAGE DRAGING THE HORSE ACROSS THE PAVEMENT!IP: Logged |
268 GT Member Posts: 111 From: Tucson, AZ USA Registered: Jul 2005
Sorry I have not posted in awhile. The project has taken a definite turn...A gentleman by the name of Steve Graber ( www.grabercars.com ) saw my project and asked if I would be interesting in changing my plans around a bit. Here is his idea: Put my twin-Busa drivetrain into one of these...
 This car will be significantly lighter than my Fiero (1200 lbs VS ~2650 lbs) and will be propelled by the same 350hp. That's a power-to-weight ratio of 3.43lbs/hp. The C6 Z06 is 6.17lbs/hp... The car will use components from my '88 parts car such as front and rear hubs/uprights and steering rack as well as the body. It will look like an '85 GT when it's finished. I am looking for GT ground effects and front/rear fascias. I still need to swap my sunroof top for a slicktop plus $$$ if anyone is interested. I will post updates as soon as they happen. Stay tuned, this project will run in some form or another. Now I need to think of another unique engine swap for my '88 GT. I'm thinking EVO VIII 4G63 with a Lancer trans or a Nissan SR20DET with a G20 trans...
------------------ Power is nothing without control.
 Twin Engine Fiero Project IP: Logged |
doublec4 Member Posts: 5368 From: Oakville, Ontario, Canada Registered: Jun 2003
holy hell------------------
 IP: Logged |
roys88fiero Member Posts: 1042 From: Tucson,AZ Registered: May 2003
Looks like your project is coming out allright. You know I am going to paint my car, but this wont happen for a bit. Maybe if you still have not found a hard top for your GT by then, I am intrerested in a sunroof. -RoyIP: Logged |
pavo_roddy Member Posts: 3323 From: New Richmond, WI Registered: Apr 2004
HI all,I hope you finish your fiero project first!!! That would be cool to insall the engines in there, any clue as to what the body would look like?? IP: Logged |
The tube chassis is now the project. It will be powered by the twin engine drivetrain and be covered in Fiero bodywork ('85 GT look).It will look like this (the shape) but not as pretty. Alex4mula's car
 IP: Logged |
1fastcaddy Member Posts: 618 From: Hays, Kansas Registered: Oct 2004
NICE! where can I get a frame like that? im a follower now------------------ Soon to be custom port fuel injected with Megasquirt! 4.5l and th-440 And Im only 18. think about when Im 30!! IP: Logged |
Currently there is only one copy. Mine will be #2. I believe the creator is planning on putting the plans together once everything is finished and fine tuned.www.grabercars.com IP: Logged |
Welded up some startup stands for the Busa engines last weekend. I will be out of town this weekend but hope to have video of BOTH of them running by the next.
IP: Logged |
Greg Z Member Posts: 1188 From: Alexandria, LA. Registered: Jun 2004
do the 4g63, you won't be disappointed!------------------
 IP: Logged |
I know I would be happy with a 4G63 setup. My friend jusy dynoed 325AWHP and 348AWTQ with bolt-ons and H20 injection on 87 octane! A rough layout of the major components of the car.
[This message has been edited by 268 GT (edited 12-04-2005).] IP: Logged |
 The fuel cell for the startup stands.
 IP: Logged |
great, now your a coffee can racer too!  ------------------ Soon to be custom port fuel injected with Megasquirt! 4.5l and th-440 And Im only 18. think about when Im 30!! [This message has been edited by 1fastcaddy (edited 12-05-2005).] IP: Logged |
Jncomutt Member Posts: 7813 From: Ballertown, CT / Charlotte, NC Registered: Apr 2001
Hmm.. with that setup layout, in order for it fit in the fiero, it looks like the engines would have to be poking into the passenger cabin, either that or the chassis extended to move the uprights back. Just looks too long from the pics. Maybe its the angle, but I dunno...IP: Logged |
Scroll to the top of this page. The Fiero plastic body panels will be attatched to the purpose built tube frame chassis.The Fiero DNA will consist of: Bodywork front uprights/hubs rear uprights/hubs name on the title Everything else will be completely custom built (excluding engines/differential) IP: Logged |
HI-TECH Member Posts: 1334 From: manteca, california Registered: Jul 2005
wow...i love that tube frame awsome....update please IP: Logged |
Update? Hmmm...let's see...oh!I received my wheels for the car on Tuesday. They are Enkei RPF1's sized 17X8 and 17X9. The fronts weigh 15.4 lbs and the rears weigh 15.9 lbs. I snagged them with worn Victoracers for a great price. As far as the actual building of the frame? We are still obtaining critical suspension components so we can design the proper geometry. I was going to use Fiero ball joints but they are $$$ and put the pivot points too far apart for our liking. We will be using heim joints throughout the entire suspension. That is where the project is right now. IP: Logged |
Scurvy Member Posts: 852 From: Arlington, Va Registered: Nov 2005
How do you register and title a hand build custom frame?IP: Logged |
Custom2M4 Member Posts: 3130 From: Winnipeg, Manitoba Canada Registered: Sep 2004
| | | quote | | Originally posted by Scurvy: How do you register and title a hand build custom frame? |
Have the thing safety checked... It can be done here, I am un sure about in the states, but any car can legally get a new VIN as a kit car if it is home built as long as it passes all the safety checks up to date. ------------------
 Custom Fiero Fiberglass IP: Logged |
It will be similar to registering a dune buggy for road use. Hopefully my car will never actually go offroad.  A few pics of the wheels...I threw them on my twin turbo Z for some shots. They actually fit the Z perfectly and can be used on both cars. Cool!
[This message has been edited by 268 GT (edited 12-23-2005).] IP: Logged |
IP: Logged |
Gokart Mozart Member Posts: 6677 From: Metro Detroit Registered: Mar 2003
New years bumpIP: Logged |
The Poopsmith Member Posts: 1130 From: Portland, OR Registered: Mar 2005
I don't know if this has been brought up yet but looks like it could be copied for the Fiero or now the tube frame car. This could inspire a new main page update from cliff if we upped the most power from 508 to 1000!http://www.zcars.org.uk/ultima/index.htm IP: Logged |
Sorry it's been so long guys. I didn't give up just been very busy with other stuff lately (trying to buy my first home...) I will keep you guys up to date, don't worry.IP: Logged |
Total ratings: 225
Good, because I have to see this finished!IP: Logged |
1986 Fiero GT Member Posts: 2347 From: Lake View, NY USA Registered: Mar 2005
...Anything new?IP: Logged |
Unfortunately no progress hasbeen made in quite awhile... Steve Graber is still busy finishing his car and I work 60 hrs per week (crammed into 4 days) so I don't have a lot of energy to spare. rest assured, it WILL happen...someday.This is a very important project for me and I don't see myself giving up. I already have all of the important parts, I just need to bolt/weld tham all together. Robert
865spd Member Posts: 794 From: Tri-Cities, Washington, USA Registered: Oct 2004
I can't wait to see it
 IP: Logged |
Any progress?IP: Logged |
Sadly not yet...
I am still working 60 hr weeks and a buddy and i are getiing ready to start our fabicating business here shortly. Just ordered a TiG, bought a tube bender, vertical press, etc... The project is still VERY important to me and it will run someday. i will be sure to keep checking back here when I have time.
Thanks to all for the support, it means a lot.
Rob------------------ Power is nothing without control.
88White3.4GT Member Posts: 1544 From: Hayward, CA Registered: Dec 2003
Progress???IP: Logged |
carnut122 Member Posts: 1941 From: Waleska, GA, USA Registered: Jan 2004
TTT-any progress?????IP: Logged |
Oslo Member Posts: 4657 From: Bemidji, MN Registered: Sep 2002
tttIP: Logged |
THE BEAST Member Posts: 1141 From: PORT SAINT LUCIE,FLORIDA,USA Registered: Dec 2000
...IP: Logged |
Chris Hodson Member Posts: 1950 From: LE CLAIRE, IOWA, 52753 Registered: Aug 2006
I say since your going plexyglass and everything is off.. and you want to cut some poundage... And you actually had the balls to start putting Busa engines into a fiero.. What the hell lol why not chop the top a few inches? Maybe use a small helicopter engine for a powerplant? IP: Logged |
thumper_64735 Member Posts: 437 From: Independence, MO, USA Registered: Sep 2006
My idea has always been to try putting a APU out of a helicopter into a car. Its the same engine used on the Y2K bike. Lightwieght - only about 80 lbs, 200HP, and around 20,000 RPM, if I remember right (I'm airframe, not engines, lol) I figure if they can put it in a bake, why not a car? Maybe one of these days I'll try it. I could just see the Wal - Mart oil change guy's eyes would do when he opened the hood to change the oil, lol. ahhh well, maybe one day!!!!!!!!!!!!!!------------------ Hmmmmmmmmm.......now if I can just talk the Army out of an engine, I bet I can get it to fit hehehehehehe >:)  IP: Logged |
HA! lol, Howd i know out of everyone, you were going to reply to that. The sound of those engines are addictive. Ive heard a crown vic with a similar engine and its like nothing else youv ever heard in a car.IP: Logged |
bumpIP: Logged |
Hey guys, it's been awhile I know. Still nothing major to report. I've been spending most of my time working on my twin turbo Z trying to get the new engine finished. The Fiero is still a priority and I will not let it get pushed to the back burner.
On another note I finally purchased one of my dream cars. I have been lusting over this car since I was 13 years old....
 Twin Engine Fiero Project[This message has been edited by 268 GT (edited 01-13-2007).] IP: Logged |
