  Will an L67 A/C compressor work on an L32?
Will an L67 A/C compressor work on an L32? by mitchjl22
Started on: 08-07-2014 02:21 PM
Replies: 2 (89 views)
Last post by: Darth Fiero on 08-07-2014 03:54 PM
mitchjl22
Report this Post08-07-2014 02:21 PM Click Here to See the Profile for mitchjl22Send a Private Message to mitchjl22Edit/Delete MessageReply w/QuoteDirect Link to This Post
Title states. I'm at the junk yard and I'm trying get to figure out if an L67 compressor fits on an L32. I just had lines made and it has the wrong compressor fitting.
-Mitch
mitchjl22
Report this Post08-07-2014 03:48 PM Click Here to See the Profile for mitchjl22Send a Private Message to mitchjl22Edit/Delete MessageReply w/QuoteDirect Link to This Post
Just FYI Darth Fiero aka Ryan at sinister performance l, just emailed me back and saI'd it would work.
-Mitch
Darth Fiero
Total ratings: 361
Report this Post08-07-2014 03:54 PM Click Here to See the Profile for Darth FieroClick Here to visit Darth Fiero's HomePageSend a Private Message to Darth FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sometime around the 2004 model year (which is when the Series 3's came out), GM switched to a scroll type A/C compressor which direct mounts to the 3800 block (no other brackets needed). These scroll type compressors also used different A/C line hookups than the earlier compressors did.
You can use an earlier type A/C compressor on a Series 3 (or Series 2 engine that came with the newer scroll type compressor) if you get the compressor mounting brackets and lines to get it mounted and hooked up to your car. The mounting points on the engine block are no different. This means you could also use the new scroll type A/C compressor on the older engines if you wanted to.
-ryan
OVERKILL IS UNDERRATED
