  Help with Tunnerpro RT
Help with Tunnerpro RT by Fieroking
Started on: 08-06-2014 09:18 PM
Replies: 4 (245 views)
Last post by: Fieroking on 08-07-2014 02:05 PM
Fieroking
Total ratings: 78
Report this Post08-06-2014 09:18 PM Click Here to See the Profile for FierokingClick Here to visit Fieroking's HomePageSend a Private Message to FierokingEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have the USB aldl cable from Red Devil and the latest version of Tunerpro RT. I have done the driver install on to my Windows 7 laptop. I start Tunerpro, load the .adx file for my 4.9 power Fiero test the connection, then try and connect to the Caddy ECM. All I get is the DA:Not Connected Flashing between connected and not, and a error count in the box next to it with a 0.0 hZ.
I am just trying to read error codes on my 4.9 any ideas????
All help is appreciated.
Joe Sokol
85 SE Daily driver with a 3.4 DOHC OBD II
88 Formula/GT 4.9 Allante Intake (My Baby)
www.fieroking.com
Total ratings: 290
Report this Post08-07-2014 01:47 AM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Usually that means you have the wrong .ADX file selected.
Is your ECM a 2240? What year was it from?
In TunerPro RT when you selected the COM port did the cable pass the self test - Note the self test is only valid with the cable plugged into the laptop and the cable NOT plugged into the vehicle.
sardonyx247
Total ratings: 219
Report this Post08-07-2014 03:34 AM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
Make sure you have the right COM port selected.
Fieroking
Total ratings: 78
Report this Post08-07-2014 01:50 PM Click Here to See the Profile for FierokingClick Here to visit Fieroking's HomePageSend a Private Message to FierokingEdit/Delete MessageReply w/QuoteDirect Link to This Post
Checked the ECM Sevrv. No. 16132240. Ran the cable test and it passed. Connected to the car and I still get the same error. However the error was there with the cable connected or not. I am checking my wiring to make sure that that 8129 is connected to Pin M.
Joe Sokol
www.fieroking.com
Fieroking
Total ratings: 78
Report this Post08-07-2014 02:05 PM Click Here to See the Profile for FierokingClick Here to visit Fieroking's HomePageSend a Private Message to FierokingEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fieroking
Member since Jun 2002
Checked the wiring Pin A8 PCM 2A/B UART Serial Data goes to ALDL Pin M. Testing the cable passes.
Ideas?
Joe Sokol
www.fieroking.com
