  Max RMP on 2.8 with beefy lil motor
Max RMP on 2.8 with beefy lil motor by gesb123
Started on: 08-06-2014 04:33 PM
Replies: 25 (440 views)
Last post by: dobey on 08-08-2014 10:35 PM
gesb123
Report this Post08-06-2014 04:33 PM Click Here to See the Profile for gesb123Send a Private Message to gesb123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Recently rebuilt motor. 30 over, small cam, blocked decked (91/2 - 1 compression), balanced ect. The shift light comes on at 3K rpm and I was wondering how far past 3K do you guys push your 2.8?
Thanks
Total ratings: 463
Report this Post08-06-2014 04:38 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ummm... you are aware that the "shift light" on the Fiero indicates shifting for economical driving, right? It does not indicate when the engine is red-lining.
fierofinder
Report this Post08-06-2014 10:03 PM Click Here to See the Profile for fierofinderSend a Private Message to fierofinderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Have you done anything to your intake to improve airflow? If not I don't think much passed 5000 does any good. At this point the engine is gasping for air.
thesameguy
Report this Post08-06-2014 11:33 PM Click Here to See the Profile for thesameguySend a Private Message to thesameguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
The only time I shift under four grand is when I am sleep driving. Like fierofinder said anything over five is a waste of time. So, somewhere between the two.
sardonyx247
Total ratings: 219
Report this Post08-07-2014 03:40 AM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
In an 85-87 the most you can go is 6012 as that is where the rev limit kicks in, the 88 has no rev limit.
At WOT the shift light kicks in at red line, (well just before) the shift light varies on throttle postion and RPM, it is all in the code.
And it is NOT gasping for air, it is the cam profile thats drops off in the upper RPM. Next being the coil.
"DRIVE IT LIKE A FIERO"
'87 Quad 4 H.O.
dobey
Total ratings: 371
Report this Post08-07-2014 10:14 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
And the valvetrain, and the intake, and the exhaust. And the flat tappet.
Going over 4500, you're almost certainly just wasting fuel, as the torque curve has already started coming down pretty quickly after 4000. Going over 5000 and you are definitely wasting gas. Don't bother unless you're on a dyno and seeing what the peak HP number is (stock peak HP is at 5200). Going over 5500 without an upgraded valvetrain, intake, exhaust, fuel, and igntion, with some tuning, and you're just taking unnecessary risk of breaking things.
Big Paul
Report this Post08-07-2014 12:39 PM Click Here to See the Profile for Big PaulSend a Private Message to Big PaulEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have taken my stock (To the best of my knowledge) 86 GT to over 7000 without it hitting any rev limiter on multiple occasions.
fierosound
Total ratings: 286
Report this Post08-07-2014 12:39 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Agreed! Look at your tach instead.
Shift by the time you hit yellow - sooner if you feel the engine "running out of air".
At that point it's no longer accelerating hard anyway.
Calgary time/temp
[This message has been edited by fierosound (edited 08-07-2014).]
Total ratings: 463
Report this Post08-07-2014 01:15 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are you positive your tach is reading correctly?
dobey
Total ratings: 371
Report this Post08-07-2014 01:56 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Stock tach doesn't even read that high. And if an aftermerket tach is reading that high, accurately, on a stock 2.8, I'd be worried about mechanical damage. The engine just isn't built for that abuse.
Total ratings: 463
Report this Post08-07-2014 02:46 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Difficult to believe that this particular "stock" 2.8 is able to rev 2500 RPM past the point where most other 2.8 engines are running out of steam.
I FAR I
Report this Post08-07-2014 03:23 PM Click Here to See the Profile for I FAR ISend a Private Message to I FAR IEdit/Delete MessageReply w/QuoteDirect Link to This Post
With a high flow fuel pump, gutted cat, ported exhaust manifolds and a cold air intake plumbed under the car with K&N filter my Fiero GT when naturally aspirated with 4 spd could pull strong to 6500 rpm in 1st to 3rd gear and hit 6000 rpm in 4th.....140 mph!
[This message has been edited by I FAR I (edited 08-07-2014).]
Report this Post08-07-2014 06:48 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
IIRC, the max horsepower point for the 2.8L engine is around 5600 RPM.
I FAR I
Report this Post08-08-2014 10:29 AM Click Here to See the Profile for I FAR ISend a Private Message to I FAR IEdit/Delete MessageReply w/QuoteDirect Link to This Post
That may be so, but with the minor changes implemented on my car, that figure and range seemed to have changed.
[This message has been edited by I FAR I (edited 08-08-2014).]
Report this Post08-08-2014 01:00 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Seem like simple changes. You should dyno it and see what was actually gained. When you say high flow fuel pump, which one?
140 Mph, is your car lowered at all?
lou_dias
Report this Post08-08-2014 01:24 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pretty sure the stock cam's advertised peak is 4800 rpm.
Grantman
Report this Post08-08-2014 01:40 PM Click Here to See the Profile for GrantmanSend a Private Message to GrantmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
without modificaitons to improve air flow, seems like the front end would be barely touching the pavement at 140?
lou_dias
Report this Post08-08-2014 02:26 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
The only problem with going over 110 is that the headlight covers tend to fly open. However, a hood vent behind the radiator fixes that...
Grantman
Report this Post08-08-2014 03:00 PM Click Here to See the Profile for GrantmanSend a Private Message to GrantmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
I picked up a spare hood to cut in some vents at some point, not because I go over 110, just like the way they look.
84fiero123
Total ratings: 325
Report this Post08-08-2014 03:15 PM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Seeing you are in Canada, don't you mean 140 KPH? If it was a made for Canada car the MPH are on the outside and MPH are on the inside, I think, I am tired I need a nap !
edit to add
OK I had to go look before I take my nap, this is obviously an after market speedo, you sure its right? Mine on my 86 SE only goes to 85 MPH.
And he said, the OP that he put a small cam in the car so I would think that means its not a stock cam.
Steve
[This message has been edited by 84fiero123 (edited 08-08-2014).]
dobey
Total ratings: 371
Report this Post08-08-2014 06:01 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
edit to add
140 kmh ~= 87 MPH. The 86 GT would have had a 120 MPH/200 kmh speedo though.
With stock tires and 4 speed for the 86 GT though, the speed at 6000 RPM in 4th gear would be 152 MPH, not 140.
I FAR I
Report this Post08-08-2014 08:51 PM Click Here to See the Profile for I FAR ISend a Private Message to I FAR IEdit/Delete MessageReply w/QuoteDirect Link to This Post
85 Fiero GT will drive at 24.3 mph per 1000 rpm in 4th gear......24.3 x 6000 rpm = 145.8 mph......My tires are 225/50 15, so I'm subtracting 1 mph per 1000 rpm......The speedo in my car is only to 140 kph, but during this run was spinning round and round in 360 degree revolutions.
I FAR I
Report this Post08-08-2014 09:01 PM Click Here to See the Profile for I FAR ISend a Private Message to I FAR IEdit/Delete MessageReply w/QuoteDirect Link to This Post
I FAR I
Member since Jan 2012
That motor is now gone....worn out after 200k km. The fuel pump was a GM unit for the Syclone and the car had a Hypertech chip. It is lowered with Suspension Technique springs.
dobey
Total ratings: 371
Report this Post08-08-2014 09:49 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
With the 195/70-14 tires (which I think are the stock size for the rear on the 85 GT), it would be about 150 MPH at 6000 RPM in 4th, and with the 225/50-15s it would be about 143 MPH at 6000 RPM in 4th.
But the 85 GT speedo only goes to 85 MPH, and would read 3.7% off from the stock tire size. Also the tachs in Fieros are known to be somewhat inaccurate at higher RPMs. At 4000 RPM though, you would have been going 95 MPH, and the speedo would be going crazy. I really doubt you made it to 6000 RPM in top gear, because the 2.8 just doesn't make power up that high, even with the minor mods you did. Even with the mods that lou_dias did on his 3.4 build, he's not making power up that high yet.
I FAR I
Report this Post08-08-2014 10:17 PM Click Here to See the Profile for I FAR ISend a Private Message to I FAR IEdit/Delete MessageReply w/QuoteDirect Link to This Post
Whatever......I'm not asking you, I'm telling you!
dobey
Total ratings: 371
Report this Post08-08-2014 10:35 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Whatever indeed.
