| | | quote | Originally posted by NightMare Cruiser:
I'm going to the track tonight to do a run or two. 3800 SC 3.4 pulley. What's the best RPM to launch at? Any other tips?
Gary
Word to the wise. I recommend first doing a check with a wideband O2 sensor to find out your exact A/F ratio. The fueling is probably close but if you go lean, engine damage can result. With the 3.4 pulley and free flow exhaust you are pushing in more air. You may need more fuel. On the subject of launch; you don't have a limited slip differential so I would just go out with the RPM'slow.
