  crank question
crank question by Fierokid87
Started on: 08-04-2014 04:02 PM
Replies: 1 (129 views)
Last post by: phonedawgz on 08-04-2014 09:27 PM
Fierokid87
Total ratings: 80
Report this Post08-04-2014 04:02 PM Click Here to See the Profile for Fierokid87Send a Private Message to Fierokid87Edit/Delete MessageReply w/QuoteDirect Link to This Post
When I had my motor rebuilt I had the engine shop install a camaro 3.1 crank. The block is an 86. Does the crank had the crank sensor wheel on it? If so how would I install a crank position sensor for DIS?
Go here to see more of my Formula: [URL=http://www.cardomain.com/memberpage/430754[/URL]
Total ratings: 290
Report this Post08-04-2014 09:27 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yep your new crank will have the 7x wheel.
This is where the sensor goes. The lower right one is the crank pick up sensor
This is most likely what your block looks like at that location
So your best bet to add the crank sensor will be to pull the engine and swap everything into a new block with the crank sensor in place.
As an alternative you can add a external 7x wheel at the front of the crank
