I searched here, and there was this other thread, but this is different.
I only hear the noise when the clutch is
disengaged. When I am idling in neutral at a stop light, there is no noise unless I rest my foot on the clutch pedal. Even the slightest pressure on the clutch pedal brings on the noise. The noise is the same, from just resting my foot on the clutch pedal, to pushing the clutch pedal all the way down for complete disengagement, and anything in between.
The first word that comes to mind is "chattering". It has a regular rhythm or cadence. Until I showed it to my mechanic (don't do much for it myself, beyond installing makeup oil) I thought it might have been coming directly from the engine. When I was a mere tadpole and had a bicycle, I saw where someone could wedge a playing card in a way that would make a "click" from every wheel spoke, as the wheel rotated. It has that regular rhythm to it. Or a clock ticking off the seconds.
I want to see if anyone already knows what I am talking about, before I go back to my mechanic. His specialty is Corvettes, but he has worked on Fiero before, and he has already done major mechanical on this one to restore it to running condition. He says that this could be related to GM having changed the supplier from Borg-Warner to Getrag. That it may have something to do with a manufacturing dimension or tolerance that got changed slightly (not by intent) when that change was made. I know that he has been looking at a tech writeup that he found online, but I am not sure whether it is something from Rodney Dickman, or The Fiero Factory.( I just Googled for that myself, but I did not find it.)
I don't have any other symptoms or problems. It is just a noise. Tolerable, but not something I particularly want. My mechanic thinks that if he starts going into this and it turns out to be this problem that he has in mind (as I just described), it will cost me an arm and a leg to repair it. He says that he would have to remove the transmission and also the engine (I think), and that he would have to use a mechanical grinder to reduce the dimension of a part by some very small fraction. I think he means part of the transmission or clutch assembly.
It's the 88 GT, 5-speed stick, dead stock, including the stock 2.8 V6 engine. It has just over 47,000 miles. I acquired it used umpteen years ago. It broke down right away (drive train problems). It sat in my garage for umpteen years until 2010, when I had it towed to this mechanic (same guy I have been talking about) and he did a thorough overhaul to get it running again. Most of the mileage was from the previous owners. He put in a re-manufactured Getrag 5-speed transmission and a standard or street duty Centerforce clutch. It's not a heavy duty or racetrack level clutch. It's got factory AC, which he overhauled and converted to R134, but I don't think it matters whether the AC compressor is running or off. I have been running with this setup since 2010, only about 3000 miles "on my watch", but I did not really become aware of this noise until just recently.
What do you think of what this mechanic is telling me? Could this be something different than what he is describing? Something that would not involve such a large mechanical work order to eliminate? Is there an easier way to diagnose it, without removing the transmission?
[This message has been edited by rinselberg (edited 08-04-2014).]
