  AC clutch cycles on and off
AC clutch cycles on and off by Mickey_Moose
Started on: 08-02-2014 02:26 PM
Replies: 3 (442 views)
Last post by: RWDPLZ on 08-03-2014 07:21 PM
Mickey_Moose
Total ratings: 144
Report this Post08-02-2014 02:26 PM Click Here to See the Profile for Mickey_MooseSend a Private Message to Mickey_MooseEdit/Delete MessageReply w/QuoteDirect Link to This Post
88 GT.
AC clutch will cycle on and then off shortly after - will continue to do this as long as I am calling for AC - would this be an indication that the system is just low?
Note: the clutch does spin when engaged and there are no 'unusual' noise coming from the compressor either.
Thanks
Report this Post08-02-2014 03:30 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sounds like it's low. If you've converted to 134a, pick up a cycle switch for 134a and install it into the receiver dryer. It will make the compressor cycle correctly for the pressures of the new refrigerant. You can readjust the R12 switch, but unless you have gauges or know how much to turn the little adjusting screw, the $15 or so for the new switch is worth it.
Lou6t4gto
Report this Post08-03-2014 07:16 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
anyone got a Part # for the 134 "cycle switch" ?? ( if you go into a "parts store" and ask for one, you get "you want a what ? what engine ? Does it have Air Conditioning ? ", no I want a AC switch for an "Ornament" ! LOL Thanks
RWDPLZ
Total ratings: 305
Report this Post08-03-2014 07:21 PM Click Here to See the Profile for RWDPLZSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yep
Clutch Cycling Switch (R-134A)
https://www.fiero.nl/forum/Forum2/HTML/000652.html
That combination of numbers should cover just about every parts store.
The black piece on the clutch cycling switch is removable, it protects the terminals in shipping.
[This message has been edited by RWDPLZ (edited 08-03-2014).]
