  Use a DA or RA sander on PO's rattle can paint job?
Use a DA or RA sander on PO's rattle can paint job? by weloveour86se
Started on: 08-01-2014 07:43 PM
Replies: 2 (192 views)
Last post by: weloveour86se on 08-02-2014 07:10 PM
weloveour86se
Total ratings: 75
Report this Post08-01-2014 07:43 PM Click Here to See the Profile for weloveour86seSend a Private Message to weloveour86seEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yup, previous owner spray painted my car...
So can I use a sander with some fine grit paper? I'm not too worried about saving the factory paint, it's trashed anyway. My car was factory silver and if I can get back down to that I should be a lot better off for paint or dip or wrap. I plan on not going below the silver. Well that's the plan anyway.
I'm very much open to any other suggestions. My car's paint is pretty bad! Plus I really wanna finish my Kahines deckvent install.
https://www.fiero.nl/forum/F...1/HTML/089703-2.html
Hand sanding SUKKS!
rogergarrison
Total ratings: 551
Report this Post08-02-2014 12:35 PM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Id DA sand it with #80, then primer the whole thing. Im a professional though, so Id prob recommend you use #180. Main thing is to keep the pad flat on the surface so you dont sand a bunch of waves and divots in the body. Parts you cant get the DA on, you have to sand by hand. DONT try using ANY kind of stripper on it...even if it says its ok...whether someone or the can says it is. You will create a nightmare.
weloveour86se
Total ratings: 75
Report this Post08-02-2014 07:10 PM Click Here to See the Profile for weloveour86seSend a Private Message to weloveour86seEdit/Delete MessageReply w/QuoteDirect Link to This Post
TY RG.
I'm on it! Screw hand sanding this whole car! No way I can paint or anything over PO's damned shaker can crap! It's all gotta come off.
Now to find a good DA.
