  4t65hd flared end
4t65hd flared end by crashmydaytona
Started on: 08-01-2014 10:40 AM
Replies: 4 (140 views)
Last post by: Darth Fiero on 08-01-2014 09:53 PM
crashmydaytona
Report this Post08-01-2014 10:40 AM Click Here to See the Profile for crashmydaytonaSend a Private Message to crashmydaytonaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does anyone know if the flared end of the line that presses into the fitting on the transmission the same type you can make with a flaring tool? I want to make my own lines and want to use the stock fittings since one has a check valve in it. Don't want to buy a flaring tool just to find out that it wont work.
Does it make a difference which way the trans fluid flows through the radiator?
Report this Post08-01-2014 02:25 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
No. You can buy fittings that will do this. Just remove the retaining clip and pull out the steel line, then simply put the clip back and press the new hose barb fitting in.
[This message has been edited by Dennis LaGrua (edited 08-01-2014).]
radrace19
Report this Post08-01-2014 03:19 PM Click Here to See the Profile for radrace19Send a Private Message to radrace19Edit/Delete MessageReply w/QuoteDirect Link to This Post
You can also replace that quick disconnect fitting that has a check ball with a threaded fitting with a check ball
That is how I'm running AN line up to the trans cooler.
I'm pretty sure the older 4T65e 97-98 had that style.
darkhorizon
Total ratings: 451
Report this Post08-01-2014 07:59 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can 30 degree flare the older lines.
Darth Fiero
Total ratings: 361
Report this Post08-01-2014 09:53 PM Click Here to See the Profile for Darth FieroClick Here to visit Darth Fiero's HomePageSend a Private Message to Darth FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
The early 4T65-E trans cooler line fittings accepted double-flared (sometimes called an inverted flare) 3/8 steel line that attached the fitting on the trans via a tube nut that is on the flared steel cooler line. Later 4T65-E's used a push-connect type cooler line connection which is completely different.
The double-flare is a 45 deg flare. AN flares are 37 deg single flares.
Most auto parts stores should sell the standard flaring tools that can do a 45 deg double flare. Note that the stock Fiero trans cooler lines that run the length of the chassis are only 5/16" diameter. It is OK to use these with a 4T65-E HD transmission provided you can hook up to them with a secure connection.
That having been said, I would NOT use the stock Fiero radiator trans cooler with a 4T65-E HD trans. You would be better off disconnecting it from the cooling loop completely and instead install a large external transmission cooler.
Contact Dave at www.tripleedgeperformance.com for info about coolers, fittings, and such. He also sells these parts.
-ryan
OVERKILL IS UNDERRATED
[This message has been edited by Darth Fiero (edited 08-01-2014).]
