  PLX Gen III wideband setup
PLX Gen III wideband setup by Tweeder
Started on: 07-29-2014 08:20 PM
Replies: 8 (267 views)
Last post by: Tweeder on 07-30-2014 05:09 PM
Tweeder
Report this Post07-29-2014 08:20 PM Click Here to See the Profile for TweederSend a Private Message to TweederEdit/Delete MessageReply w/QuoteDirect Link to This Post
These are the instructions for it. For the narowband conection, what pin will it goto in the pcm for my 3800 swap?
darkhorizon
Total ratings: 451
Report this Post07-30-2014 09:09 AM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dont use narrowband simulation
Tweeder
Report this Post07-30-2014 09:39 AM Click Here to See the Profile for TweederSend a Private Message to TweederEdit/Delete MessageReply w/QuoteDirect Link to This Post
No, how come? If it's not there, how will the PCM make changes in fuelling if I were to put the wideband in it's place. I wasn't planning on running them both if the one will do the same job as two. I was thinking the PCM will take the signal from the narrowband pin at the wideband.
darkhorizon
Total ratings: 451
Report this Post07-30-2014 12:36 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
It is very inaccurate. The pcm is Looking for a very specific signal that the plx is not generating
nosrac
Total ratings: 50
Report this Post07-30-2014 01:36 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
I planned on getting one of these as I like the dual o2 feature.
Do you have a working 3800 swap or are you in the process of building one?
Tweeder
Report this Post07-30-2014 03:12 PM Click Here to See the Profile for TweederSend a Private Message to TweederEdit/Delete MessageReply w/QuoteDirect Link to This Post
If your talking to me, than I have a working swap and am in the process of upgrading some performance parts and my aemuego went tits up so this is my replacement. But it's a lot more detailed that the aem one.
Tweeder
Report this Post07-30-2014 04:56 PM Click Here to See the Profile for TweederSend a Private Message to TweederEdit/Delete MessageReply w/QuoteDirect Link to This Post
Tweeder
Member since Aug 2012
I was looking on the plx website an here's some more info to go along with darkhorizon.
http://www.plxdevices.com/AppNotes/PLXApp004.pdf
nosrac
Total ratings: 50
Report this Post07-30-2014 05:05 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was asking because I figured you would just tap into o2 connector to feed pcm.
Tweeder
Report this Post07-30-2014 05:09 PM Click Here to See the Profile for TweederSend a Private Message to TweederEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ah I see. I think I'll run both after reading a bit mor into it as I'm not willing to cut and hack to add the resistors.
