  Ponitac not starting
Ponitac not starting by what would a josh do
Started on: 07-27-2014 01:24 PM
Replies: 14 (245 views)
Last post by: Patrick on 07-29-2014 01:04 AM
Report this Post07-27-2014 01:24 PM Click Here to See the Profile for what would a josh doSend a Private Message to what would a josh doEdit/Delete MessageReply w/QuoteDirect Link to This Post
So I have a 1987 pontiac fiero with a 4 cylinder engine. Just replaced the clutch on it and just put back in the engine. Then we realize the fuel injector is not spray fuel. So we changed it out, checked the fuel lines, and made sure the carburetor was clean and it still isn't injecting fuel. The car turns over just isn't getting any fuel. Anybody know the what the problem is?
Total ratings: 466
Report this Post07-27-2014 03:15 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Start with the basics... Is there enough gas in the tank? Don't trust the fuel gauge.
Does the fuel pump prime for two seconds when you turn the ignition switch on?
Report this Post07-27-2014 03:36 PM Click Here to See the Profile for what would a josh doSend a Private Message to what would a josh doEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yea I put 1/2 gallon of gas in the tank, and I checked the fuel pump. Just the gas goes into the carburetor, but it doesn't spray out the fuel injector.
Report this Post07-27-2014 03:45 PM Click Here to See the Profile for what would a josh doSend a Private Message to what would a josh doEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since Jul 2014
Report this Post07-27-2014 04:35 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Josh, your car has a throttle body fuel injector....no carburetor. Check your fuse box.
Report this Post07-27-2014 05:28 PM Click Here to See the Profile for what would a josh doSend a Private Message to what would a josh doEdit/Delete MessageReply w/QuoteDirect Link to This Post
I checked all the fuses and none of them are broken, checked over all the wires I could think of and they all are connected. We think its something to do with the main computer.
unplugged1981
Report this Post07-28-2014 10:49 AM Click Here to See the Profile for unplugged1981Send a Private Message to unplugged1981Edit/Delete MessageReply w/QuoteDirect Link to This Post
Before bumping your main computer check your engine light codes, here is a vid that might help you.
https://www.youtube.com/watch?v=sRoSMhEL3Ms
mike-ohio
Report this Post07-28-2014 11:17 AM Click Here to See the Profile for mike-ohioClick Here to visit mike-ohio's HomePageSend a Private Message to mike-ohioEdit/Delete MessageReply w/QuoteDirect Link to This Post
does the tach move when cranking the engine?
Fuel injector will not spray without and ignition working.
Report this Post07-28-2014 11:56 AM Click Here to See the Profile for what would a josh doSend a Private Message to what would a josh doEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes the tach works, but the fuel injector still doesn't spray.
Total ratings: 291
Report this Post07-28-2014 12:09 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Turn the key to on but don't crank. Does the ECM turn on the fuel pump for 2 seconds and then does it turn off? It should.
Does the check engine light come on? It should.
Bump (Just a bump) the starter. Does the fuel pump come on again and then turn off? It should.
If these are failing then check for power to the ECM before replacing it.
Connector C2 - White check for the following:
Pin 10 Orange - Should have +12 all the time
Pin 15 Orange - Should have +12 all the time
Pin 15 Pink/Black - Should have +12 when the key is on
Report this Post07-28-2014 09:19 PM Click Here to See the Profile for what would a josh doSend a Private Message to what would a josh doEdit/Delete MessageReply w/QuoteDirect Link to This Post
no the check engine light does not come on.
84fiero123
Total ratings: 325
Report this Post07-28-2014 10:38 PM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
unplug and plug your injector leads just before the injector and any other wires going to you injector further back. I had a bad plug on one once and had to hard wire it, cut it and solder it.
its something stupid and simple I can almost guarantee it.
Steve
Report this Post07-28-2014 10:51 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
That means that the ECM is not getting power. Check the reset connector near the battery.
Report this Post07-28-2014 11:13 PM Click Here to See the Profile for what would a josh doSend a Private Message to what would a josh doEdit/Delete MessageReply w/QuoteDirect Link to This Post
ok thx guys I figured out the dumb EMC reset connector wasn't connected. Finally Its running
Total ratings: 466
Report this Post07-29-2014 01:04 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Blaming the "dumb EMC reset connector", eh?
Thanks for reporting back as to the cause/solution.
