  ENGINE MOUNTS
ENGINE MOUNTS by RPYRAZOO
Started on: 07-27-2014 11:14 AM
Replies: 4 (537 views)
Last post by: Dennis LaGrua on 07-29-2014 11:01 PM
RPYRAZOO
Report this Post07-27-2014 11:14 AM Click Here to See the Profile for RPYRAZOOClick Here to visit RPYRAZOO's HomePageSend a Private Message to RPYRAZOOEdit/Delete MessageReply w/QuoteDirect Link to This Post
When changing engine mounts on a stock 2.8, should the auto. tranny. mounts be changed? Also, can rubber and poly mounts be used together and which vendor is the best to buy the parts from? I have a poly. dogbone from the FS and am wondering if I should go poly on the mounts.
Thanks again,
Rich
katatak
Total ratings: 82
Report this Post07-27-2014 07:57 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would replace them all - Stock rubber type. Poly in the dog bone is good but you don't need it for the motor or trans mounts. Stock rubber keeps the vibrations out of the drive train and makes for a better ride.
RPYRAZOO
Report this Post07-27-2014 08:34 PM Click Here to See the Profile for RPYRAZOOClick Here to visit RPYRAZOO's HomePageSend a Private Message to RPYRAZOOEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for letting me know which way to go with this. Where would you go for parts?
Rich
mcguiver3
Report this Post07-27-2014 09:20 PM Click Here to See the Profile for mcguiver3Send a Private Message to mcguiver3Edit/Delete MessageReply w/QuoteDirect Link to This Post
I've gotten mine from AutoZone If not in stock, only a day to get them.
Napa is another source, they should be able to get them too.
Report this Post07-29-2014 11:01 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
When a rubber engine/trans mount is 25+ yrs old it's usually in need of replacement. Agree with using rubber mounts although I use poly mounts and twin dog bones on my 3800SC. While the engine sits solid, you do feel vibrations at idle but at road speed I notice no difference. If the engine is stock rubber mounts are the way to go. .
