Update System
  sound from front brakes
by TheDigitalAlchemist
Started on: 07-25-2014 10:23 PM
Replies: 6 (165 views)
Last post by: TheDigitalAlchemist on 07-28-2014 04:57 PM
TheDigitalAlchemist
Total ratings: 94
Report this Post Click Here to See the Profile for TheDigitalAlchemistClick Here to visit TheDigitalAlchemist's HomePageClick Here to Email TheDigitalAlchemistSend a Private Message to TheDigitalAlchemistEdit/Delete MessageReply w/QuoteDirect Link to This Post
1986.
When I'm moving, I hear a little single metallic 'tap' sound coming from the front brakes if I press the brakes even a little bit. Any idea what might be causing it? I don't feel anything, the brakes seem fine... I haven't gotten a chance to look at the wheels. Pads have about 1000 miles on 'em.
Thanks in advance for your replies
-TDA
NW-Fiero
Report this Post Click Here to See the Profile for NW-FieroSend a Private Message to NW-FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Both brakes, Right and Left. Until you have a chance to pull the wheels and inspect, I find it hard to assist. New Bearings?, Loose bearings nut?, new rotors when pads installed??
Mark
' 85 2m6 3.4PR
In the Great Northwest!
84fiero123
Total ratings: 325
Report this Post Click Here to See the Profile for 84fiero123Click Here to Email 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by TheDigitalAlchemist:
1986.
-TDA
A Tap? Just sounds weird, as if something is lose, do you get it when going in both directions?
Steve
[This message has been edited by 84fiero123 (edited 07-26-2014).]
cmechmann
Report this Post Click Here to See the Profile for cmechmannClick Here to Email cmechmannSend a Private Message to cmechmannEdit/Delete MessageReply w/QuoteDirect Link to This Post
Some inner pads don't sit tight in the saddle. Gravity makes then sit on the bottom ear and when you hit the brakes the pad moves against the top ear. Have have a cheap set on my 85 right now. The Wagner inners are just a little too thick with new rotors and I'm waiting for the new outers to wear a little.
The cheap pads fit "loose" and tap when the brake is applied. This can also cause them to rattle over bumps on extreme cases.
With the caliper off put the pad in the saddle. See if you can move them up and down. If you have enough space and don't want to try different pads you can use a Ford Pinto/Mustang II inner pad anti rattle clip on the bottom of the pad to take up the space.
Also a worn saddle will give the same result no matter what pad you use.
TheDigitalAlchemist
Total ratings: 94
Thanks guys, I'll check it out and let ya know what I find.
Jason88Notchie
Report this Post Click Here to See the Profile for Jason88NotchieClick Here to Email Jason88NotchieSend a Private Message to Jason88NotchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would second this diagnosis. When the pads are new this seem to be a non issue from what I have experienced. And for some reason it seems to happen in the right front typically.
TheDigitalAlchemist
Total ratings: 94
pad was worn, also needed new wheel bearing.
