  C203 shorting out. Intermittent CEL Fuel pump runs weird.
C203 shorting out. Intermittent CEL Fuel pump runs weird. by mitchjl22
Started on: 07-25-2014 01:56 PM
Replies: 3 (120 views)
Last post by: mitchjl22 on 07-25-2014 06:17 PM
mitchjl22
Report this Post07-25-2014 01:56 PM Click Here to See the Profile for mitchjl22Send a Private Message to mitchjl22Edit/Delete MessageReply w/QuoteDirect Link to This Post
I was installing my Speedo conversion circuit for my 3800 swap, when I was trying to probe for switched power, I found this short. I have no idea whew it's coming from, or where I should look, or even how to find it.
Any help or suggestions welcome.
mitchjl22
Report this Post07-25-2014 02:01 PM Click Here to See the Profile for mitchjl22Send a Private Message to mitchjl22Edit/Delete MessageReply w/QuoteDirect Link to This Post
UPDATE: When I wiggle PIN F it freaks out. How do I fix a bad connection on pin F?
Total ratings: 290
Report this Post07-25-2014 02:11 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any chance your car is dying at times also? Pin F is switched power to the ECM.
Open the clear connector. Take a small screwdriver and untang the Pin F connector and pull it out backwards. Bend the connector so the pin then makes a tight contact when inserted. Reassemble.
It might also be a problem with a less than tight crimp on the Pin F terminal. Once you have the wire out check it. Solder if needed. There is a possibility that the copper wire is broken inside the plastic coating.
Revised -
I see you are installing my speedo buffer. Isn't there a replacement pin on the buffer already for pin F of C203? So the speedo buffer will replace the suspected pin correct?
I sure hope it isn't that the problem is that my pin F terminal on the speedo buffer is at fault.
btw when things disconnect electrically that should be connected we call that an open. A short is when two things connect that should not be connected.
[This message has been edited by phonedawgz (edited 07-25-2014).]
mitchjl22
Report this Post07-25-2014 06:17 PM Click Here to See the Profile for mitchjl22Send a Private Message to mitchjl22Edit/Delete MessageReply w/QuoteDirect Link to This Post
Your connector is great and replaces pin G. Pin F is not altered. I reseated the connector and no problems now. Thanks for the quick reply.
[This message has been edited by mitchjl22 (edited 07-25-2014).]
