  Air goes hot
Air goes hot by AL
Started on: 07-23-2014 11:09 AM
Replies: 6 (157 views)
Last post by: jaskispyder on 07-23-2014 07:04 PM
AL
Report this Post07-23-2014 11:09 AM Click Here to See the Profile for ALSend a Private Message to ALEdit/Delete MessageReply w/QuoteDirect Link to This Post
I charged air and it works great when I'm driving but as soon as I stop it shoots hot air but when I get going it goes cold again, what could it be?
jaskispyder
Total ratings: 205
Report this Post07-23-2014 11:13 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did you use a guage? Could still be low, or you have compressor problems, or....
Do you have a leak, or did you replace something and recharge it?
dobey
Total ratings: 371
Report this Post07-23-2014 11:21 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Problem with the radiator fan, or the condenser?
edit: And to build on what jack was asking, did you fill it with R134-a without doing the full proper conversion?
[This message has been edited by dobey (edited 07-23-2014).]
jaskispyder
Total ratings: 205
Report this Post07-23-2014 11:23 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
could also be plugged filter... maybe
TopNotch
Total ratings: 60
Report this Post07-23-2014 02:34 PM Click Here to See the Profile for TopNotchClick Here to visit TopNotch's HomePageSend a Private Message to TopNotchEdit/Delete MessageReply w/QuoteDirect Link to This Post
See if your radiator fan turns on when you turn on the AC. If not, that's the problem. You need moving air for it to work.
AL
Report this Post07-23-2014 05:41 PM Click Here to See the Profile for ALSend a Private Message to ALEdit/Delete MessageReply w/QuoteDirect Link to This Post
I changed the compressor the filter and the condenser, I charged it and no leaks, also my fan does work
jaskispyder
Total ratings: 205
Report this Post07-23-2014 07:04 PM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did you pull a vacuum and hold it? How did you charge it?
New compressor? R12 or 134a?
