  lazy eye
lazy eye by ironhead.76
Started on: 07-17-2014 08:25 PM
Replies: 8 (665 views)
Last post by: Csjag on 07-19-2014 03:41 PM
ironhead.76
Report this Post07-17-2014 08:25 PM Click Here to See the Profile for ironhead.76Click Here to visit ironhead.76's HomePageSend a Private Message to ironhead.76Edit/Delete MessageReply w/QuoteDirect Link to This Post
88 formula.
When I turn head lights on only left light goes up. I can manually lift headlight part ways and turn lights off then both lights work properly. For a couple days, then back to lazy eye. Sometimes they work fine. Recently it started a new trick. The parking lights would not come on but both headlights work properly. Today I replaced the headlight switch so maybe the parking light issue is solved.
What direction should I take to find the issue? Does anyone know?
Report this Post07-17-2014 09:49 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I suspect the nylon bushing things in the headlight motor have turned to white dust. That'll make sense when you take it apart. The other motor is probably about to have the same issue. Go to Rodney's site and find his replacement bushings.
dobey
Total ratings: 371
Report this Post07-17-2014 10:36 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yep. Time to rebuild the motors. It's a pretty easy job. Just get the rebuild kits, and plan to spend more time taking the headlights out and putting them back in, and re-aligning them, than it takes to do the actual rebuild.
ironhead.76
Report this Post07-18-2014 08:35 AM Click Here to See the Profile for ironhead.76Click Here to visit ironhead.76's HomePageSend a Private Message to ironhead.76Edit/Delete MessageReply w/QuoteDirect Link to This Post
I replaced the bushing with rodnys a month after I bought the car, which would make it a year ago.
I replaced the headlight switch now it seems as both headlights work properly. Note I said seems
ironhead.76
Report this Post07-18-2014 09:20 AM Click Here to See the Profile for ironhead.76Click Here to visit ironhead.76's HomePageSend a Private Message to ironhead.76Edit/Delete MessageReply w/QuoteDirect Link to This Post
ironhead.76
Member since Aug 2012
How do you check and diagnose a headlight module?
Boostdreamer
Total ratings: 98
Report this Post07-18-2014 03:02 PM Click Here to See the Profile for BoostdreamerSend a Private Message to BoostdreamerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Could just be the relay. I'd swap them before I did anything else.
[This message has been edited by Boostdreamer (edited 07-18-2014).]
Csjag
Report this Post07-18-2014 06:06 PM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
Also check the connector to the headlight relay, one of mine had a loose wire that would sometimes make contact and sometimes not make contact. A good way to check the relay itself is to switch it to the opposite side and see if it works there. They are interchangeable from side to side.
ironhead.76
Report this Post07-19-2014 11:29 AM Click Here to See the Profile for ironhead.76Click Here to visit ironhead.76's HomePageSend a Private Message to ironhead.76Edit/Delete MessageReply w/QuoteDirect Link to This Post
My car has the second gen headlight system. It has the module. I'm not sure if it has one them relays. I will look again.
Csjag
Report this Post07-19-2014 03:41 PM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
Opps you are right, 88's had the less complex system
