  bad clutch ?
bad clutch ? by fieroloco
Started on: 07-16-2014 07:12 PM
Replies: 2 (90 views)
Last post by: Gall757 on 07-16-2014 08:27 PM
fieroloco
Report this Post07-16-2014 07:12 PM Click Here to See the Profile for fierolocoClick Here to visit fieroloco's HomePageSend a Private Message to fierolocoEdit/Delete MessageReply w/QuoteDirect Link to This Post
hi all
i have a fiero 84. which I put a 3.1 engine from Cuttlas 94 with Isuzu transmission of a fiero 85 . which clutch you should put because I put a clutch for fiero 85 . but now the clutch is get in burn and no walks forward only reverse . what is wrong with this swap ? someone helpme
[This message has been edited by fieroloco (edited 07-16-2014).]
Neils88
Total ratings: 56
Report this Post07-16-2014 08:00 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Please use punctuation....your single long sentence was very hard to read.
I believe the stock 3.1 puts out around 140hp, 185 ft lb. The stock 4cyl, 5sp clutch would likely not be able to handle this for too long. The heavy duty version would be the better option.
http://www.fierostore.com/P...spx?s=54006&d=79&p=1
Report this Post07-16-2014 08:27 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ha! Consider it done!! Bueno!
That said, I couldn't punctuate Spanish either.
