  LS4/Procharger question
LS4/Procharger question by Steve25
Started on: 07-12-2014 03:32 PM
Replies: 13 (839 views)
Last post by: gmctyphoon1992 on 07-16-2014 03:31 AM
Steve25
Report this Post07-12-2014 03:32 PM Click Here to See the Profile for Steve25Send a Private Message to Steve25Edit/Delete MessageReply w/QuoteDirect Link to This Post
In a Fiero with an LS4, if you look really hard, is there room for a Procharger?
dobey
Total ratings: 371
Report this Post07-12-2014 03:38 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Depending on the water pump you use, how your alternator is mounted, and if you have an a/c compressor run by the engine too, it could be possible.
A small turbo would be much easier to do, though.
Report this Post07-12-2014 04:03 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cantilever it off the front of the engine in the battery tray area or use a jackshaft (like the magnachargers) to drive the procharger mounted off the rear of the heads (over the transmission).
infinitewill
Total ratings: 85
Report this Post07-13-2014 08:51 AM Click Here to See the Profile for infinitewillSend a Private Message to infinitewillEdit/Delete MessageReply w/QuoteDirect Link to This Post
[This message has been edited by infinitewill (edited 01-05-2016).]
Steve25
Report this Post07-13-2014 10:06 PM Click Here to See the Profile for Steve25Send a Private Message to Steve25Edit/Delete MessageReply w/QuoteDirect Link to This Post
dobey, I am just not a fan of turbos. I will be doing a dual exhaust so it would be TT.
fieroguru, I believe that you have an LS4 Fiero? Or have done a swap? The jackshaft may be a way to go. Routing the air would be interesting. I was planning to use the upper part of the trunk for an after cooler.
Will, Yeah, I think it would be fun. Maybe you can pick me up a blem from the factory.
[This message has been edited by Steve25 (edited 07-13-2014).]
Report this Post07-13-2014 10:23 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Steve25:
fieroguru, I believe that you have an LS$ Fiero? Or have done a swap? The jackshaft may be a way to go. Routing the air would be interesting. I was planning to use the upper part of the trunk for an after cooler.
Correct, I did a LS4/F40 swap to my personal Fiero.
Website: fieroguruperformance.com
Products: 88 13" Brake Kit, 88 12" Brake Kit, 88 Lateral Link Relocation, 84-87 Machined Front Hubs, Custom Machining
Engine Swaps:
LS4/F40, HSR/SBC/F23, Pro-Flo/383/Getrag, 4.3CPI/4T60, Ramjet SBC/Getrag, 4.9/Isuzu, Carb SBC/Isuzu, 4.5/Isuzu
[This message has been edited by fieroguru (edited 07-13-2014).]
Steve25
Report this Post07-14-2014 01:46 PM Click Here to See the Profile for Steve25Send a Private Message to Steve25Edit/Delete MessageReply w/QuoteDirect Link to This Post
It will be an LS4/4T65E-HD.
So you think that it is possible?
If I go ahead with this project I would like to have the Procharger mounting and placement already determined to avoid doing something that will make it difficult or impossible later.
Thanks,
Steve
Steve AT 88GTP DOT com
88 GT\3800 SC\L67\L26\4T65E-HD (Retired)
Report this Post07-14-2014 03:31 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
I certainly think its possible, but it will require extensive design and fabrication for either method.
There is quite a bit of room to work with in the engine bay:
Steve25
Report this Post07-14-2014 05:35 PM Click Here to See the Profile for Steve25Send a Private Message to Steve25Edit/Delete MessageReply w/QuoteDirect Link to This Post
Very nice install!!!!!!!!!!!!!!!!!!!!!!!!
Thanks for the pic. It may be doable.
Report this Post07-15-2014 08:01 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Why not use the top end of an LS9?
gmctyphoon1992
Report this Post07-15-2014 02:49 PM Click Here to See the Profile for gmctyphoon1992Send a Private Message to gmctyphoon1992Edit/Delete MessageReply w/QuoteDirect Link to This Post
correct me if im wrong but I seem to remember someone trying to put an LS2 manifold on an LS4 and it wouldnt line up and didnt fit. Was that you Fieroguru? I remember you working with the LS2 intake or trying too anyways
[This message has been edited by gmctyphoon1992 (edited 07-15-2014).]
Report this Post07-15-2014 03:20 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Several LS4's are currently running LS2 intake manifolds and the picture of my LS4 shown above has an LS2 intake on it as well. They can be made to fit and how much work that takes really depends on if you plan to keep DoD or not.
dobey
Total ratings: 371
Report this Post07-15-2014 03:27 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
The picture you're referring to had the intake sitting backwards. They fit just fine after a small modification to the oil pressure sending unit boss on the valley cover.
Edit: Found the image you were talking about:
[This message has been edited by dobey (edited 07-15-2014).]
gmctyphoon1992
Report this Post07-16-2014 03:31 AM Click Here to See the Profile for gmctyphoon1992Send a Private Message to gmctyphoon1992Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yea thats exactly it. good find sir
