  How to remove sunroof bolts?
How to remove sunroof bolts? by FieroCat
Started on: 07-08-2014 02:52 PM
Replies: 1 (650 views)
Last post by: seajai on 07-08-2014 05:17 PM
FieroCat
Report this Post07-08-2014 02:52 PM Click Here to See the Profile for FieroCatSend a Private Message to FieroCatEdit/Delete MessageReply w/QuoteDirect Link to This Post
One of the sunroof pins (on the front of the glass that slides into the front of the sunroof opening) on my Fiero's sunroof is very loose, and in trying to tighten it and remove it altogether, I cannot get it to unscrew. There is no way to get a grip on the flat side of the bolt on top of the glass. How are these removed?
My Fiero: 1986 Pontiac Fiero GT, V6, 4-speed manual
seajai
Total ratings: 52
Report this Post07-08-2014 05:17 PM Click Here to See the Profile for seajaiSend a Private Message to seajaiEdit/Delete MessageReply w/QuoteDirect Link to This Post
The tabs loosen up because the plastic washer underneath the tab disintegrates. There isn't a way to tighten the screws any more, they need to be replaced along with the washer and nut. I purchased all the parts for mine through the Fiero Store. To remove the screw from the nut (the part on the outside of the sunroof glass) you will need to cut a slot through the black cap and into the metal so you can hold it with a flat blade screwdriver. Mine was a big pain to get apart. Get all the parts gathered before you start.
http://www.fierostore.com/P...d=190&nq=0&p=1&sz=50
[This message has been edited by seajai (edited 07-08-2014).]
