  Question for electrical wizards
Question for electrical wizards by countach711
Started on: 07-08-2014 02:33 AM
Replies: 6 (274 views)
Last post by: countach711 on 09-17-2014 03:39 AM
countach711
Report this Post07-08-2014 02:33 AM Click Here to See the Profile for countach711Click Here to visit countach711's HomePageSend a Private Message to countach711Edit/Delete MessageReply w/QuoteDirect Link to This Post
I bought some linear actuators off Ebay and while they are supposed to be 12 volt, the leads have four pins in them. The wiring harness/system I bought only has 2. Any ideas on how to connect them? Need more info? These are to replace the headlight motors for my Countach build.
jb1
Report this Post07-08-2014 03:09 AM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
look at spec sheet that should have came with it , really only need 2 wires red and black the others are for feed back and control., you can use a motor controller to make it stop at a given point without an external limiting switch..
(series II swap in progress)
85GT Northstar/ 4t80e
86GT 3800 n/a---sold
Northstar Rebuild
Total ratings: 290
Report this Post07-08-2014 08:19 AM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
They could be a stepper motor. If they are controlled by a stepper motor you will need a stepper motor controller for them.
http://www.haydonkerk.com/?TabId=86
countach711
Report this Post07-09-2014 12:28 PM Click Here to See the Profile for countach711Click Here to visit countach711's HomePageSend a Private Message to countach711Edit/Delete MessageReply w/QuoteDirect Link to This Post
thanks for the ideas and comments guys. Here's a link to the controller and wiring system I bought for it.
http://www.ebay.com/itm/111...id=p3984.m1439.l2649
Here is the actuator http://www.ebay.com/itm/301...id=p3984.m1439.l2649
The leads to plug in the actuators only have 2 wires so I assume the controller controls it. Go figure. So do you think if I cut open the leads off the actuators I will find one red, one black and the non-essential wires will be other colors? I guess it's worth a try as I will need to put another plug on it regardless.
(edit to provide linear actuator link.)
[This message has been edited by countach711 (edited 07-09-2014).]
Total ratings: 290
Report this Post07-09-2014 12:46 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
If there are only two wires then apply voltage to them and see what happens. Reverse the voltage and the action should reverse.
tebailey
Report this Post07-09-2014 03:40 PM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
The actuators I've worked with had 4 wires and the control unit had 4 feed wires. The length of the actuator was controlled by which combination of wires were powered. They were used as throttle controls on heavy equipment.
countach711
Report this Post09-17-2014 03:39 AM Click Here to See the Profile for countach711Click Here to visit countach711's HomePageSend a Private Message to countach711Edit/Delete MessageReply w/QuoteDirect Link to This Post
Got these wired up and working. Turns out after I cut the 4 pin connectors off there were only two wires feeding them. Go figure.
