  Horn issues & Ebrake issues
Horn issues & Ebrake issues by Reesh91
Started on: 07-06-2014 07:51 PM
Replies: 3 (146 views)
Last post by: theogre on 07-07-2014 05:08 PM
Reesh91
Report this Post07-06-2014 07:51 PM Click Here to See the Profile for Reesh91Send a Private Message to Reesh91Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have two issues, first thing is my horn now doesn't work, yet when I hit the horn button the interior light at my feet turns on and buzzes, no sound comes out of the horn. Second is my ebrake doesn't work I pull and it has tension then it falls right back down to the ground, brake light on dash turns on but no brake is working. Any ideas how to fix either one.
zzzhuh
Report this Post07-06-2014 07:57 PM Click Here to See the Profile for zzzhuhSend a Private Message to zzzhuhEdit/Delete MessageReply w/QuoteDirect Link to This Post
A really good write up for the E brake is actually on the main page of this site. Here is the link:
https://www.fiero.nl/cgi-bin/main.cgi?EBrakeAdjust
As far as your horn not working, has it worked when you first got the car? The fact the light is going on seems like an 'interesting' electrical issue. Check out simple things like the fuses, and connections to the horn. Im almost leaning towards the horn was rerouted and wasn't fully connected by the previous owner?
PaulJK
Total ratings: 237
Report this Post07-07-2014 03:46 AM Click Here to See the Profile for PaulJKSend a Private Message to PaulJKEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by zzzhuh:
Check out simple things like the fuses ...
Yep. screwy electrical issues usually come from a blown fuse somewhere. When a fuse blows, you would normally think that something just stops working. Nope - not GM. The circuit will find all kinds of alternate paths. Checking all your fuses is a good place to start. Maybe even check the fuses themselves with a meter before putting them back in. I've had fuses "look" good but wouldn't pass current.
Report this Post07-07-2014 05:08 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
See my Cave, Horn and Rear Brakes
