  Battery/Engine temp console gauge cluster housing...
Battery/Engine temp console gauge cluster housing... by buhockey56789
Started on: 07-04-2014 08:28 PM
Replies: 2 (173 views)
Last post by: seajai on 07-05-2014 12:36 AM
buhockey56789
Report this Post07-04-2014 08:28 PM Click Here to See the Profile for buhockey56789Click Here to visit buhockey56789's HomePageSend a Private Message to buhockey56789Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have an 88GT with the battery gauge/engine temp gauge in a cluster housing that is perched atop the radio/heat-a/c controls. Unfortunately the housing's screw holes have cracked so the whole housing is flopping around. The guages still work as the cable is still good. The screw eyelets are still good in the dash. Is there anywhere to buy a new housing? I'll post some pictures soon.
buhockey56789
Report this Post07-04-2014 08:40 PM Click Here to See the Profile for buhockey56789Click Here to visit buhockey56789's HomePageSend a Private Message to buhockey56789Edit/Delete MessageReply w/QuoteDirect Link to This Post
Here are the pictures of the housing (remains of the screw anchors) and the dashboard (intact screw eyelets)
seajai
Total ratings: 51
Report this Post07-05-2014 12:36 AM Click Here to See the Profile for seajaiSend a Private Message to seajaiEdit/Delete MessageReply w/QuoteDirect Link to This Post
You could try epoxy to glue it back together. Unfortunately its a pretty common issue, 25 years of sun and heat makes the plastic brittle. Don't believe anyone is reproducing them. Your best bet is to put a "wanted" ad in the mall section.
[This message has been edited by seajai (edited 07-05-2014).]
