  4T65-E Pan
4T65-E Pan by Fierotregg
Started on: 06-25-2014 09:50 PM
Replies: 2 (86 views)
Last post by: Lou6t4gto on 06-26-2014 02:14 PM
Fierotregg
Report this Post06-25-2014 09:50 PM Click Here to See the Profile for FierotreggSend a Private Message to FierotreggEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is the a torque sequence to putting on the trans pan on a 4T65-E?
MulletproofMonk
Total ratings: 78
Report this Post06-26-2014 12:18 AM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
https://www.fiero.nl/forum/Forum2/HTML/125149.html
-Brian
Removing the roof panel
My HUD install thread
Modified stock air canister and base to 3.5 inch for 3800na
Lou6t4gto
Report this Post06-26-2014 02:14 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
if you're asking about the Transmission side cover hard rubber gasket with metal inserts, it's a reusable gasket , and you just go 12 oclock to 6 to 9 to 3 , so on so on at about 15lbs. I just put some High Tack on both surfaces. never had a leak . the bottom pan, just some high tack and the same method .
