  Flywheel resurface
Flywheel resurface by LornesGT
Started on: 06-25-2014 12:48 AM
Replies: 7 (671 views)
Last post by: Patrick on 06-26-2014 02:36 PM
LornesGT
Report this Post06-25-2014 12:48 AM Click Here to See the Profile for LornesGTSend a Private Message to LornesGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
So I have read here that .806 for the flywheel thickness is still good to go. I measured mine today and it is .606 and need some work. The clutch didn't slip even having oil on it, at least I couldnt tell. What is the minimum you have tried? Is there a shim available?
Report this Post06-25-2014 03:03 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Do you have the original flywheel?
or I should ask: Is your flywheel original equipment or did someone put in an aftermarket one? I have never encountered that much variation in thickness.
[This message has been edited by Gall757 (edited 06-25-2014).]
Kevin87FieroGT
Report this Post06-25-2014 03:41 PM Click Here to See the Profile for Kevin87FieroGTSend a Private Message to Kevin87FieroGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I always thought a resurfacing of the flywheel without cleaning up rivet scoring so would only remove .010" each time it was done. Can't imagine with rivet scoring it would be a whole lot more unless done numerous times, or by a hack in the back room.
There are shims available in varying thicknesses. Check Rock Auto, Summit, or your local speed shop.
[This message has been edited by Kevin87FieroGT (edited 06-25-2014).]
LornesGT
Report this Post06-25-2014 10:29 PM Click Here to See the Profile for LornesGTSend a Private Message to LornesGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have no idea how to tell if OEM?
If I add a shim should I add enough to get back to .806?
bigals
Report this Post06-26-2014 09:20 AM Click Here to See the Profile for bigalsSend a Private Message to bigalsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes shims will get the spacing right. Go for either the same height or within 20 thousands will be ready to go
rogergarrison
Total ratings: 551
Report this Post06-26-2014 09:59 AM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ill just take a guess and say that an OEM will have a GM number on it somewhere.
trotterlg
Report this Post06-26-2014 02:04 PM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
How and where are you measuring the thickness? Larry
Report this Post06-26-2014 02:36 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
We had a good discussion regarding the use shims in my flywheel thread HERE.
[This message has been edited by Patrick (edited 06-26-2014).]
