  Smoke from inside engine bay?
Smoke from inside engine bay? by FieroCat
Started on: 06-24-2014 11:57 AM
Replies: 3 (404 views)
Last post by: fastblack on 06-24-2014 11:43 PM
FieroCat
Report this Post06-24-2014 11:57 AM Click Here to See the Profile for FieroCatSend a Private Message to FieroCatEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did a Seafoam treatment the other day and put some into the brake booster vacuum hose. While doing so, I noticed some of the exhaust smoke coming up from behind the engine where the rear spark plugs were (It's the V6 2.8L). Would this just be a bad exhaust manifold gasket, or something worse? It only did it for a short time and I didn't notice anything else unusual.
My Fiero: 1986 Pontiac Fiero GT, V6, 4-speed manual
jaskispyder
Total ratings: 205
Report this Post06-24-2014 12:05 PM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
could be anything
cracked manifold, broken bolt, bad pipe, bad y-pipe connection, bad gasket.
Do you hear a ticking noise?
trotterlg
Report this Post06-24-2014 02:24 PM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Or you just dripped a little on the engine when you were putting it into the break booster hose. Larry
fastblack
Total ratings: 50
Report this Post06-24-2014 11:43 PM Click Here to See the Profile for fastblackSend a Private Message to fastblackEdit/Delete MessageReply w/QuoteDirect Link to This Post
I wouldn't worry too much, as stated, you may have just dripped some Seafoam onto a hot manifold. If it makes you feel any better, I've been running my car with a cracked front manifold since I bought it 5-6 years ago. I've gotten used to the ticking and my wife says it wouldn't be my Fiero without it. I don't fix it because I have nightmares of broken manifold bolts
[This message has been edited by fastblack (edited 06-24-2014).]
