  Phonedawgz Wiring Harness Questions
Phonedawgz Wiring Harness Questions by Bahrbarian
Started on: 06-23-2014 08:56 AM
Replies: 7 (843 views)
Last post by: Bahrbarian on 06-25-2014 08:22 AM
Bahrbarian
Report this Post06-23-2014 08:56 AM Click Here to See the Profile for BahrbarianSend a Private Message to BahrbarianEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello everyone,
I'm hoping that someone can answer a couple of questions regarding a harness that Phonedawgz built for my 3800 na swap in an 84 automatic. I've sent him PMs but haven't gotten a response in over a month.
Anyway, my questions are, what coolant temp sensor should I be using? The harness has a two wire oval plug but my 3800 has a round three pin connector. Also, I had asked for the optional wire that you can ground for the performance shifting mode for the 4t65e but I don't see it on the harness.
I'm hoping that someone that got a harness from him in the past can help me out. Thanks in advance!
Bahrbarian
Report this Post06-24-2014 08:22 AM Click Here to See the Profile for BahrbarianSend a Private Message to BahrbarianEdit/Delete MessageReply w/QuoteDirect Link to This Post
Anyone even have a guess on this one?
KY87fierogt
Report this Post06-24-2014 09:03 AM Click Here to See the Profile for KY87fierogtSend a Private Message to KY87fierogtEdit/Delete MessageReply w/QuoteDirect Link to This Post
Temp sensor: Tu-178 at autozone. If you want a different brand just cross reference.
Fierotregg
Report this Post06-24-2014 09:32 AM Click Here to See the Profile for FierotreggSend a Private Message to FierotreggEdit/Delete MessageReply w/QuoteDirect Link to This Post
If I remember right, my performance shift wire was white. I can double check when I get home.
Report this Post06-24-2014 02:28 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The performance shift is terminal #21 on the clear PCM connector.
The wire color is dark blue. Grounding this wire will signal performance shift if the PCM is programmed for that option.
Using the two wire connector (yellow and black) would allow PCM to read coolant temperature. The three wire ( yellow, black, and dark green) would also provide for the Fiero temperature gage.
The gage reads via pin C-2 in the C-500 connector.
JamesCurtis
Total ratings: 64
Report this Post06-24-2014 10:56 PM Click Here to See the Profile for JamesCurtisSend a Private Message to JamesCurtisEdit/Delete MessageReply w/QuoteDirect Link to This Post
What's the best way people have gotten a hold of him? I sent him an e-mail about a month and a half ago and never heard back about an issue I'm having with his wiring harness. Don't mean to derail the thread, just curious.
Tony Kania
Total ratings: 305
Report this Post06-25-2014 12:47 AM Click Here to See the Profile for Tony KaniaSend a Private Message to Tony KaniaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Have you tried PMing him? (Not sure if that is what you meant by email.) He is often found here in Tech. I know I get busy. Perhaps he is? He has been a huge help to our Fieros. I don't see him as purposely ignoring you.
Wish I could be of more help. Good luck...
Bahrbarian
Report this Post06-25-2014 08:22 AM Click Here to See the Profile for BahrbarianSend a Private Message to BahrbarianEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the info again everyone, that should take care of me. I also would like to say that Phonedawgz has been very helpful to me in the past, even offering to meet me as we only live maybe a couple of hours away and he travels my way occasionally. I'm not sure why he hasn't answered PMs or emails lately even though I have seen him helping out in the tech section in the same timeframe, but I'm sure he has a good reason. We all get busy sometimes...
Thanks again everyone!
