  3800sc run's weird at start up?
3800sc run's weird at start up? by deezil
Started on: 06-22-2014 10:45 PM
Replies: 5 (163 views)
Last post by: deezil on 06-24-2014 09:51 AM
deezil
Report this Post06-22-2014 10:45 PM Click Here to See the Profile for deezilSend a Private Message to deezilEdit/Delete MessageReply w/QuoteDirect Link to This Post
I Let my 3800sc powered fiero sit for about 2 months and it has developed a wierd running issue when started up.
It basically revs a bit and drops a bit and does that for a while. I can drive it and it seems to go away. It has full power . After a short drive it doesn't show any of the issues. Turning it off and back on after driving around it doesn't show any of the issues. Just when it's cold and has been sitting for a bit.
Any Ideas?
Total ratings: 290
Report this Post06-22-2014 11:49 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is the difference that the battery is disconnected during these long times? If so it's normal.
deezil
Report this Post06-23-2014 07:28 AM Click Here to See the Profile for deezilSend a Private Message to deezilEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Battery is connected during the down time. It's a red top optima.
fierofan25
Report this Post06-23-2014 01:58 PM Click Here to See the Profile for fierofan25Send a Private Message to fierofan25Edit/Delete MessageReply w/QuoteDirect Link to This Post
idle air control valve.
Fierorog
Report this Post06-23-2014 10:02 PM Click Here to See the Profile for FierorogSend a Private Message to FierorogEdit/Delete MessageReply w/QuoteDirect Link to This Post
What are you running for an air filter? I Have a K+N on mine and it will do the same thing. I don't think the computer is set to to adjust with that much air flow. Not sure, it goes away pretty quick foe me.
deezil
Report this Post06-24-2014 09:51 AM Click Here to See the Profile for deezilSend a Private Message to deezilEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's a k&n but its been fine for 1000 miles
