Hi im rebuilding my front end and other parts like fuel tank and im building a 3800 modded engine so here are my question and yes i searched so here are my technical question
1. does it have a fuel pump plug and play without modification to the fuel sending unit for 400-450 hp range i only find plug and play fuel pump for up to 300 hp ( i dont want to modify the fuel tank sending unit because if i want to put the 2.8 in a couple years i will just have to put a new oem pump )
2. if it is just converting wires from the pump connector i will not have a problem to repin the wire . walbro FT200000169 ?????? one said the
http://www.highflowfuel.com...fiero-1985-1988.html but want to make sure one try it and can support 400-450 hp range i saw an article about all listed the 255 lph at different pressure and want a professionnal answer with technical info to make sure ( how to make sure it is not a chinese model or junk like that ) ????
3.. if i dont have time to finish my 3800 this summer can i run these type of pump for the 2.8 ?????? ( will i have too more return pressure volume on the return line ???? ) strange question maybe dump but just to make sure
3. about the pulsator does it will fit on these type of pump ???? does the more fuel will break it or i will have problem with it ???? i prefer to keep it because if gm made it it was for a reason
4. i searched about cleaning the inside of the tank and saw multiple thread about cleaning inside of the tank with acid ...... ( i will send at a rad shop if you recommend to clean it )
so i remove the sending unit and i looked on the hole where the sending unit are and it have no rust clean inside tank no baffle broke nothing like new . do you think i will need to clean it or keep it like that because im the type of guy who love make all the things myself because im perfectionnalism and always know that sometime shop will dont take care of your car like all we did . i dont want to have hole in a couple years and really hate rust and thats why i asked these question
5. i remove the fuel sendind unit and i was impressed that there was no rust like new condition so do you think i need to change it for a new on fiero store to not have to drop the tank in a few years or you will keeping it like that ???????
6. what did you do to restore the outside of the tank ???? sanding 180 220 ???? wire brush ?????? what type of primer ???? type of paint ?????
thanks all for your help
