  Some Info Needed About Fiero Store Fuel Pump 255 LPH And Plastic Brake Clip
Some Info Needed About Fiero Store Fuel Pump 255 LPH And Plastic Brake Clip by fierogtx
Started on: 06-20-2014 09:01 PM
Replies: 5 (485 views)
Last post by: fierogtx on 06-21-2014 11:46 PM
fierogtx
Report this Post06-20-2014 09:01 PM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
i need some infor about the fierostore fuel pump 255lph i searched here and just found info about the stock fiero store pump so here are my question about the 255 LPH
1. what is the brand of the pump
2. does anyone try it with a heavy modded engine ????
3. can it handle 400 450 hp range we dont have many info about that pump pressure .....
4. where to find original black plastic brake metal line where are mount front spare tire cover im looking for the oem clip not aftermarket does anyone have found that type of clip or have a part number ??????
thanks all
[This message has been edited by fierogtx (edited 06-20-2014).]
2002z28ssconv
Total ratings: 51
Report this Post06-20-2014 11:27 PM Click Here to See the Profile for 2002z28ssconvClick Here to visit 2002z28ssconv's HomePageSend a Private Message to 2002z28ssconvEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry for not answering your specific question, but please allow me to offer a recommendation.
If you really just want 255 LPH... ($99)
But if you want to make sure you're supplying enough fuel for 400 - 450 hp, ($169 - same price as the one you're trying to find data for)
[This message has been edited by 2002z28ssconv (edited 06-20-2014).]
fierogtx
Report this Post06-21-2014 09:37 AM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
thanks i did search but i definitively want a fuel pump that is plug and play and dont need modification . the ep381 will not support my mod so im searching a fuel pump that can just fit in without modification
2002z28ssconv
Total ratings: 51
Report this Post06-21-2014 12:58 PM Click Here to See the Profile for 2002z28ssconvClick Here to visit 2002z28ssconv's HomePageSend a Private Message to 2002z28ssconvEdit/Delete MessageReply w/QuoteDirect Link to This Post
Correct, I had to modify this section of the sender assembly in order to install the sock. I had forgotten about that.
[This message has been edited by 2002z28ssconv (edited 06-21-2014).]
hnthomps
Total ratings: 50
Report this Post06-21-2014 01:39 PM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I also recommend the very quiet DW pumps. The mod is very trivial and should not impact the install process.
Nelson
fierogtx
Report this Post06-21-2014 11:46 PM Click Here to See the Profile for fierogtxSend a Private Message to fierogtxEdit/Delete MessageReply w/QuoteDirect Link to This Post
does anyone know if you can put a plug and play fuel pump for 400hp and more hp without modifying ?????
and does anyone saw the pastic clip on a parts store ????
