  Help Please
Help Please by markkrug
Started on: 06-14-2014 07:56 AM
Replies: 10 (367 views)
Last post by: 84fiero123 on 06-18-2014 09:28 AM
markkrug
Report this Post06-14-2014 07:56 AM Click Here to See the Profile for markkrugSend a Private Message to markkrugEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have an 88 GT with a 2.8 engine and 5 speed. Problems started driving on the interstate at about 65 MPH. My car started to buck, sputter, and backfire. I got to where I was going and let the car sit. After a few hours, I got it started and it got me home with only some small issues. I later change the fuel filter and the car ran fine for the trip home. Next time I drove it, same issue of sputtering and backfires. I had the car checked and found that my EGR tube and O2 sensor were bad. A Rodney Dickman replacement, a new O2 sensor, distributor cap and rotor later, the car ran fine. Fine for about a day or two. Back to the same sputtering and backfiring. I took it back to the shop and they drove for about an hour with no issues to speak of (backfired once on the road but could not get it to so it in the shop).
I then drove it again and it ran like a champ. For about 2 days. Then halfway home from work it began to sputter and backfire (under load) and barely made it home. I died in the driveway and I was able to get it started again and limped into the garage. Now it will not start at all.
1) Checked fuel pressure and got the fuel geyser so I do not think it is that.
2) Car was checked and there are no vacuum leaks since the EGR tube was replaced.
3) The tach shows about 900 RPM when cranking so I do not think it is the ICM.
Any thoughts, directions, etc. would be GREATLY APPRECIATED. I am at my wits end. I have diagosed and searched for answers and I hate the idea of having to have it towed to a shop to have them try and fumble with a diagnosis.
Thanks in advance, FYI - the car has about 43000 miles.
Mark
PaulJK
Total ratings: 237
Report this Post06-14-2014 08:00 AM Click Here to See the Profile for PaulJKSend a Private Message to PaulJKEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ignition coil, distributor module, pick-up coil, distributor cap and rotor - all routine maintenance items that could be the source of the problem you describe. When i had a v6, i replaced them all every 20-25 thousand miles. If you do all these and still have a problem, check the spark plug wires or plugged catalytic converter too.
[This message has been edited by PaulJK (edited 06-14-2014).]
Robertzep2
Report this Post06-14-2014 09:18 AM Click Here to See the Profile for Robertzep2Send a Private Message to Robertzep2Edit/Delete MessageReply w/QuoteDirect Link to This Post
I second PaulJK's opinion. Weak spark; no matter what part of the ignition system will cause your symptoms.
KY87fierogt
Report this Post06-14-2014 09:37 AM Click Here to See the Profile for KY87fierogtSend a Private Message to KY87fierogtEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ignition control modules can fail in different ways. The most common symptom is the car will die and can not restart until it cools down(if even then). Another way I have seen it fail is the car will take a little longer to start and/or will have a miss/backfire. This may not be your problem but I wouldn't dismiss it just because the tach moves while cranking. Good luck.
lateFormula
Report this Post06-14-2014 10:03 AM Click Here to See the Profile for lateFormulaSend a Private Message to lateFormulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I third Paul's opinion. I have experienced ignition problems on a few cars that all displayed similar symptoms, especially under load. In my experience it was most often a plug wire gone bad, but I would suggest you replace plugs and wires first, then test it. If problem still persists then I'd check the cap+rotor and the ECM.
[This message has been edited by lateFormula (edited 06-14-2014).]
Total ratings: 290
Report this Post06-14-2014 12:21 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ignition coil, but before you replace it make your plugs needs to be properly gapped (INCLUDING THE FRONT 3) and your spark plug wires need to be less than 10K ohm per foot or at least no older than 3 years old.
hookdonspeed
Total ratings: 131
Report this Post06-14-2014 12:22 PM Click Here to See the Profile for hookdonspeedClick Here to visit hookdonspeed's HomePageSend a Private Message to hookdonspeedEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by phonedawgz:
(INCLUDING THE FRONT 3) .
this made me lol
markkrug
Report this Post06-14-2014 05:15 PM Click Here to See the Profile for markkrugSend a Private Message to markkrugEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the suggestions. I will let you know what fixes it.
markkrug
Report this Post06-18-2014 02:12 AM Click Here to See the Profile for markkrugSend a Private Message to markkrugEdit/Delete MessageReply w/QuoteDirect Link to This Post
I got a new ignition coil, installed it and started right up. I bouhht the ICM also but have not replaced it yet. Should I do that or wait till it goes out? I plan on getting new plugs and wires soon. Any advice?
PaulJK
Total ratings: 237
Report this Post06-18-2014 02:23 AM Click Here to See the Profile for PaulJKSend a Private Message to PaulJKEdit/Delete MessageReply w/QuoteDirect Link to This Post
When the ICM goes out, it'll leave you stranded. If it was me, i'd do it now. Taylor wires and NGK UR5 plugs and you'll be good to go
[This message has been edited by PaulJK (edited 06-18-2014).]
84fiero123
Total ratings: 325
Report this Post06-18-2014 09:28 AM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
put that song up because that has always been my philosophy on replacing parts to see what one is broke, that and I like the song,
But back to the problem at hand,
replace one part at a time to make sure you are replacing the part that is the problem, also testing each part before replacing it can save you a lot of time and money.
by the way my vote is the pickup coil, take a look at it, if the protective plastic wrap is worn off then it is probably the problem, especially if the problem only rears its ugly head when its raining or the humidity is high.
Steve
[This message has been edited by 84fiero123 (edited 06-18-2014).]
