| quote | Originally posted by fierogtx:
hi im just putting a new front suspension and many parts like brake line ... i have many question about parts cleaning painting and .... so here are my question 1.about the coolant pipe question i have a little rust where the brackets was and what to do to remove rust from it ????? does the steel wool will remove some anti corrosion product .... i was thinking to sandblast it and powdercoat it ?????? dont know if the paint will affect the coolant pipe to release heat from the paint. i want to know what you do to your coolant pipe |
The coolant pipes are stainless steel (409 grade), so using steel wool to clean them up won't hurt them.
| quote | 2.about the stabilizer bar if i sandblast it does it will affect the rigidity of the stabilizer bar |
Nope, but it may roughen the surface where it is clamped with the sway bar bushings on the front chassis, which means you will really ned to grease the bushings.
| quote | 3.when i remove the bolts from the crossmember rom the bottom of the crossmember we have 4 bolts to remove 2 at each side and one of these 4 bolts are a little bit longer does it is normal and dont know where that longer bolt goes does anyone know where you put it or saw that ?????? |
Don't know. I've never had to pull the front crossmember on a Fiero.
