  Pioneer deck install
Pioneer deck install by Odin
Started on: 06-11-2014 01:58 AM
Replies: 10 (353 views)
Last post by: Fiervette on 06-14-2014 09:03 PM
Odin
Report this Post06-11-2014 01:58 AM Click Here to See the Profile for OdinSend a Private Message to OdinEdit/Delete MessageReply w/QuoteDirect Link to This Post
My old pioneer deck quit. Went out and picked up a new one. It uses a smaller harness. I have a gm aftermarket stereo harness pluged into the fiero harness, the new pioneer harness gets connected to that. I'm having difficulty getting the thing to turn on. My car is an 88gt with the performance sound option. Anyone know what the small harness with with 2 wires is for? Is the constant12v and the switched power on the large harness with the ground?
Scottzilla79
Report this Post06-11-2014 02:22 AM Click Here to See the Profile for Scottzilla79Send a Private Message to Scottzilla79Edit/Delete MessageReply w/QuoteDirect Link to This Post
This might help.
Fiero Radio Wiring
Odin
Report this Post06-11-2014 10:04 AM Click Here to See the Profile for OdinSend a Private Message to OdinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the reply. I have tried using those diagrams. The problem is that there are actually 2 harnesses my car has in there. One with only two wires on it orange and brown I believe. Then a second main harness which has all the speakers and the ground. My last deck was hooked up using a combination of these two harnesses. It's a little confusing I can't seem to get power to it.
[This message has been edited by Odin (edited 06-11-2014).]
TopNotch
Total ratings: 60
Report this Post06-11-2014 11:13 AM Click Here to See the Profile for TopNotchClick Here to visit TopNotch's HomePageSend a Private Message to TopNotchEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you can get a wiring diagram of the old head unit, you can find out which wires do what by tracing back from that.
bomluuk
Report this Post06-11-2014 06:19 PM Click Here to See the Profile for bomluukSend a Private Message to bomluukEdit/Delete MessageReply w/QuoteDirect Link to This Post
On the smaller harness, only one of the wires is used for the pioneer. The adapter harness should only have one wire coming from it (stereo side). Look at the color of the wire and reference it to the link that was provided in the first reply. If it's orange, thats your constant 12V and should be wired to the yellow on the pioneer harness. If its yellow on the car, it is your switched 12V and should be wired to the red on the pioneer harness.
BrittB
Report this Post06-13-2014 09:27 PM Click Here to See the Profile for BrittBSend a Private Message to BrittBEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fuse or a ground is where I'd look.
James Bond 007
Total ratings: 263
Report this Post06-13-2014 10:10 PM Click Here to See the Profile for James Bond 007Send a Private Message to James Bond 007Edit/Delete MessageReply w/QuoteDirect Link to This Post
I like to use a small 12v electric motor to test the wires. Im sure you probubley allready know this, one wire is intermitant power (poweres the sterio, key on and off) and one wire is a constant 12V, for the sterio clock and memory.The remainder is your speaker wires.
PaulJK
Total ratings: 237
Report this Post06-14-2014 05:51 AM Click Here to See the Profile for PaulJKSend a Private Message to PaulJKEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm gonna guess that the orange is a power wire and the brown is for illumination. Your radio should have 4 wires:
Power in RUN - this is power to turn the radio ON and OFF
Power Constant - this is power that keeps your saved radio station pre-sets in memory
Illumination - this dims the display when you turn your lights ON
Ground
Personally, I never do wiring without a multimeter. With a coupon, you can get one for free at Harbor Freight with a purchase [this should be worth a + ]
http://www.harborfreight.com/digitalsavings.html
[This message has been edited by PaulJK (edited 06-14-2014).]
sardonyx247
Total ratings: 219
Report this Post06-14-2014 06:20 AM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
on the 2 prong harness
ORG in Cont +12V
BRN is for the dimmer
Are you using the "performance sound" sub?
if so there additional wireing to get it to turn on, as the later decks have a power out.
"DRIVE IT LIKE A FIERO"
'87 Quad 4 H.O.
huracan2015
Report this Post06-14-2014 12:56 PM Click Here to See the Profile for huracan2015Send a Private Message to huracan2015Edit/Delete MessageReply w/QuoteDirect Link to This Post
I just did the same thing to my car a few weeks ago. I literally messed around with it until it worked becasue I don't know anything about wiring, but now I do. In my case, it was a yellow and orangw wire. Those are the power wires. The other harness simply connects to the speakers.
Fiervette
Report this Post06-14-2014 09:03 PM Click Here to See the Profile for FiervetteSend a Private Message to FiervetteEdit/Delete MessageReply w/QuoteDirect Link to This Post
Like Sardonyx247 said, since you have the premium sound that you need to hook up power to the subwoofer amp. This connection is not referenced in the wiring diagram you were linked to. On connection E there are 2 pink wires which power the amp. This would be a single wire on the adapter plug. This connection needs to be powered when the radio is switched on. So, the obvious thing to do is use the power antenna connection. This is normally the blue wire on an aftermarket stereo. One problem with this is the aftermarket radios only output enough current on this connection to energize a relay. The power antenna output is not meant to drive a load such as an amp. I had a woomp, woomp sound constantly when hooked mine up. I had to hook up an accessory relay that was switched on with this connection and powered through the yellow wire. Let me if you need more detail on the relay connections.
